Bamboo Eradication - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By Johnny_inFL
  • 1 Post By chiraldude
  • 1 Post By ChuckTin
  • 2 Post By chandler48
  • 1 Post By stacik84
Old 05-08-2019, 07:55 AM   #1
Rewards Points: 52
Bamboo Eradication
Can someone verify whether the attached pictures show Bamboo? I know there are several varietals.
They have been planted prior to owning the house as a privacy wall against the woody area. They have recently multiplied quite a bit this spring and has started to take over some of the edges on the lawn.
Has anyone had experience with eliminating them? Any specific herbicide I should be using? Glyphosate or would a home-made Vinegar/Salt solution be effective?
Any help is appreciated. Thanks!
stacik84 is offline   Reply With Quote
Old 05-08-2019, 08:12 AM   #2
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,166
Re: Bamboo Eradication
best of luck in your project !!
as you noticed, it is spreading underground. this is their habit.
depending on where you are in the world, and what poisons you
have access to, will determine your eradication methods.
Bondo likes this.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is offline   Reply With Quote
Old 05-08-2019, 08:52 AM   #3
Rewards Points: 701
Hard to tell for sure but the stem nodes look like bamboo.
This looks like a dwarf variety? Not nearly as much trouble as the full sized varieties.
Bamboo is somewhat resistant to glyphosate but it is resistant to most herbicides as well. It is resistant but not immune. Spray it now, wait a month and see what new shoots come up. Wait long enough for the leaves to fully unfurl since glyphosate is only absorbed through leaves. You will probably need spray 3-4 times through the summer then repeat for a couple of years to completely kill it.
stacik84 likes this.
chiraldude is offline   Reply With Quote
Old 05-08-2019, 08:58 AM   #4
Rewards Points: 78
I would cut them off a convenient length above the ground an _immediately(!)_ paint the shoots with concentrated brush killer. Immediately is important to cause the plant to absorb the erradicator into the root system. Plus you will most likely be doing this more than once to get it all out.
ChuckTin is offline   Reply With Quote
Old 05-08-2019, 12:20 PM   #5
DoomsDave's Avatar
Rewards Points: 2,592
@stacik84 , I don't think that's bamboo, though it bears a superficial resemblance.
Maybe take a closeup of a leaf? That looks like a "dicot" or broadleafed plant, instead of a grass, which is what bamboo is.
That said, I concur generally with @ChuckTin and @chiraldude about control methods, though a positive ID can help sometimes. Bamboo's big Achilles heel is that it takes a while for it to reestablish after it's been ravaged, and continuing efforts will kill it off. Other plants can be tougher.
DoomsDave is offline   Reply With Quote
Old 05-08-2019, 01:10 PM   #6
Looks like Japanese knotweed. If so it is very hard to kill. Glyphosate will knock it back but it still might resprout.
Sent from my SM-G900V using Tapatalk
cmwhitmoyer is offline   Reply With Quote
Old 05-08-2019, 07:17 PM   #7
Naildriver
chandler48's Avatar
Rewards Points: 2,064
We have found that the only way to curb the spread of bamboo is to drive overlapping steel plates into the ground, at least 24" deep. It keeps the roots from seeking new ground and will contain it in a reasonable area if you should want to grow it for food or for plant supports.
Bondo and MTN REMODEL LLC like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 05-08-2019, 08:08 PM   #8
Rewards Points: 1,454
Doesn't look like any bamboo I've seen in China, Hawaii & California.
Nik333 is online now   Reply With Quote
Old 05-08-2019, 08:17 PM   #9
Where are you, in general?
Old 05-08-2019, 08:22 PM   #10
Rewards Points: 52
Boston MA
Nik333 likes this.
Old 05-09-2019, 04:33 PM   #11
Every bamboo I've seen has spiky leaves, looking like knife blades.
Old 05-09-2019, 06:59 PM   #12
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,062
Ayuh,...... I don't care what the plant is, hit with Clorox bleach a couple times, 'n it'll DIE,....
Bamboo, ya gotta chase the new shoots for awhile, but it is killable,....
Bamboo flooring anyone with experience with Costco Strand woven or others ctaylor619 Flooring 1 09-08-2013 12:55 AM
Bamboo vs Hardwood bluefoxicy Flooring 11 11-25-2012 12:10 PM
To use, or not to use Bamboo... dmcandy Flooring 10 08-23-2012 12:19 PM
Glue down (and glue seams) Master's Choice Bamboo floor? JohnMtl Flooring 1 01-14-2012 12:36 PM
Bamboo Eradication Jupe Blue Landscaping & Lawn Care 11 02-28-2010 08:35 AM
