Back Yard Get's Very Soggy After Rainfall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bondo
Old 06-02-2016, 12:58 PM   #1
Rewards Points: 2
Back yard get's very soggy after rainfall
I have a sloping back yard that levels out into a wooded area. The yard is about 100ft by 60ft The last 10-15 feet half of that yard (the lowest lying part) gets very soggy after rainfall and stays that way for a while. My theory is that all the water travels downhill (both surface and subsurface) to the back of the yard and then takes a while to absorb because the soil is not very porous.
I was thinking of putting in a 3-4 ft deep french drain filled with gravel (pipe then gravel all the way up with the last 6 inches being soil for grass) a few feet uphill of the portion of the yard that gets soggy. I'm thinking that this will catch most of the surface and subsurface water that is making its way downhill and this will get rid of my soggy backyard problem. I would daylight the drain into a culvert on the side of the property and also potential a deep dry well (thinking of using the NDS Flo-well).
Would love to hear the communities thoughts on this idea.
vbreyter is offline   Reply With Quote
Old 06-02-2016, 03:16 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Back yard get's very soggy after rainfall
Ayuh,.... Yer right, water flows downhill, no way 'round it,......
The problem I see with yer plan, is placement,....
Put the drain at the very bottom, in the soggyist spot, 'n pitch the drain to the culvert,.....
mathmonger likes this.
Tags
curtain drain , french drain , yard drainage
Small Back Yard Suggestions? costgeek Landscaping & Lawn Care 4 05-23-2015 07:03 AM
What is this strange grass in my back yard mmunro2003 Landscaping & Lawn Care 3 04-22-2013 09:18 PM
soggy yard w/ponds drainage issues sonicbloom214 Landscaping & Lawn Care 3 09-21-2011 11:44 AM
gravelling a soggy yard needtoknow Landscaping & Lawn Care 6 04-25-2011 10:12 AM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 06:44 AM
