Attaching Perferated Pipe - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-06-2014, 09:31 PM   #1
Rewards Points: 53
Attaching perferated pipe
I am running a huge drainage piping down my front hill yard. How do I attach different corrugated piping segments together? How do you attach the corrugated piping to the drains? Thanks for the help.
tucker0104 is offline   Reply With Quote
Old 12-07-2014, 06:15 AM   #2
Rewards Points: 17,912
Couplings and drain adaptors.
Any Lowes or HD will have them.
Just make sure you measure what size down spout you have.
Old 12-07-2014, 06:16 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,.... With Couplers, 'n Fittin's,....
Where ever ya got the drainage tile, oughta have the fittin's ya need,...
Old 12-07-2014, 08:52 PM   #4
Rewards Points: 1,754
I built a huge drainage system in my yard years ago, from corrugated. Looking back, and if I ever do it again, I will use black or white plastic sewer pipe, not the corrugated stuff. Reasons, -easier to do connections that will be more root-proof, the corrugations hold stagnant water that breed mosquitoes and traps leaf debris and roof granules which start blocks, and readily-available takeout connectors for the plastic pipe, (and DO put in lots of takeouts)
ChuckF. is online now   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
oh'mike (12-08-2014)
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
How to protect PVC pipe when soldering near it? Studly Plumbing 8 11-21-2011 10:10 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
