Artificial Grass Over Concrete? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-07-2017, 04:12 PM   #1
Rewards Points: 208
artificial grass over concrete?
I have plans to pull out the old concrete, and lay new slabs with raised beds, but the costs is several thousand and we have other more important plans that need to happen before that project.
As a work around I was considering laying artificial grass OVER the existing concrete until the re-slabbing can be done. Seems like a quick and easy project just buy, cut, and glue the grass over the concrete. Has anyone done this yet and if so what advice / company did you use for grass.
Here is a sample video I found.
LGHTme is offline   Reply With Quote
Old 08-14-2017, 01:41 PM   #2
Rewards Points: 208
Re: artificial grass over concrete?
Update:
I had a rep come out and he said it would be pretty easy to do since I already have a large drain in the center and the concrete tappers toward that drain. Since I have a curving edge he suggested I make a large template first and put that on the back of the grass and cut the grass then lay and test.
My only concearn is the amount of heat coming off the grass when it sits in full sun. Seems like we won't be able to walk on it bare feet after all. Does anyone know if there is grass that is actually cool enough to walk on? I don't mind spending a little extra per square foot since it's such a small space.
Old 08-14-2017, 03:09 PM   #3
Rewards Points: 102
Err, maybe an umbrella over the turf until your ready for the big project?
subbuilder is offline   Reply With Quote
Old 08-14-2017, 03:14 PM   #4
retired framer
Rewards Points: 20,738
Heard tell of people fencing it to keep kids and pets off as it was to hot.
Old 08-14-2017, 03:58 PM   #5
Rewards Points: 208
I have cover already, but it only covers half of the patio. The half that gets sun seems to get hot. Not horribly hot, but it does get hot. I could walk on it barefoot as well as my 2 year old, but he said "dada it's HOT" and walked away. I think there are some walls to keep it cool, but I'm not doing a sand infill so it won't work.
ultimate concrete hardness Yodaman Concrete, Stone & Masonry 12 05-04-2015 06:47 PM
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 04:15 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
