Ariens Snowblower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-12-2017, 07:30 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 238
Ariens Snowblower
I have an Ariens 870 snowblower.
It seems just recently when I get into a high snow area, the snowblower will slow down, I almost have to push it., like it loses power under a load.
The engine does not seem to slow, just the drive mechanism.
What adjustment to I have to make??
Is it a loose drive cable?
Barry
Barry J is offline   Reply With Quote
Old 02-12-2017, 01:55 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: Ariens Snowblower
Ayuh,.... It's it a belt driven machine,..??
If so, that's the 1st place to look,....
Bondo is online now   Reply With Quote
Old 02-12-2017, 04:56 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,168
Bondo's correct as a first step. The drive belt could have become glazed. If not, check to see if the belt tensioning is within specs. This info is usually in the owner's manual.
I don't know Arien, but if the drive system uses a 'slipper wheel' - where a drive idler contacts a large driven disc at various locations on its radius depending on the 'gear' selected, the surfaces of either may have become glazed. If so, you can try roughening them up with some sandpaper. If that doesn't work, they might need replacing. One final note - if you did some preventive maintenance in that area and used grease on some sliding surfaces, you may have used too much and it has flung off and got on the wheel. I've done it. Clean it off with a bit of varsol.
lenaitch is online now   Reply With Quote
Old 02-12-2017, 04:57 PM   #4
Rewards Points: 17,912
What's the whole model #?
Broken shear pin?
Ariens snowblower damaged by "eating" hose Manny32 Landscaping & Lawn Care 3 02-03-2011 08:09 AM
Snowblower Repair FF_Thor General DIY Discussions 0 11-29-2010 03:51 PM
Ariens Snowblower Axle Wont Turn BW02916 Tools 3 11-14-2010 12:45 PM
ariens snowblower george61 Tools 1 08-18-2010 03:54 PM
ariens snowblower traction skidad Tools 2 12-17-2007 04:32 PM
