Always Shut Off Fuel Shutoff Valve? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-06-2015, 07:13 AM   #1
From Philadelphia
Rewards Points: 291
Always shut off fuel shutoff valve?
I have various mowers/blowers/etc., some which have fuel shutoff valves. Do you shut off this valve after each use? I usually shut it off BEFORE turning the mower off so that any excess gas in the carb gets burned off and doesn't gum up the carb. It makes logical sense in my head to do this, but is this proper/standard procedure, or is this overkill? What do you do?
hellohello is offline   Reply With Quote
Old 09-06-2015, 07:23 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 54
Never have (and I've been around for 70+ years). At the end of the season, I drain the tank and then run the engine dry.
But certainly what you are doing doesn't hurt it.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 09-06-2015, 09:54 AM   #3
Rewards Points: 2,800
No need to do it after every use.
After the last usage of the season, shut off the valve and then run the engine until it goes off. It does help to burn off as much remaining gas in the carburetor as possible before long term storage.
Finally suck out the remaining gas from the gas tank or pour in some Sta-Bil or similar gasoline preservative.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 09-06-2015, 11:44 AM   #4
Rewards Points: 5,348
I'd check the instructions and do what's suggested.
It's also insurance if the bowl float sticks down and gas continues to fill and overflow the carburetor and spill on the floor.
Ron
B. Franklin 1759
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 01:29 AM
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 05:34 PM
shut of and drain valve placementin Home Run Heating Vkazman Plumbing 1 02-25-2012 07:54 AM
Main Water Shutoff Valve leak & question leemort Plumbing 50 02-12-2012 08:25 AM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 09:55 AM
