Advice On Fire Pit Seating Area - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 09-19-2017, 08:53 AM   #1
Rewards Points: 8
Advice on Fire Pit seating area
So the wifey wants a fire pit. We are doing a 16-18 square area with railroad ties for the border. She wants small river rock or pea gravel for the sitting area. So my question is do I need to dig down a few inches to put in a base layer? Or can I simply kill the grass, cover with landscape fabric, put down a honeycomb stabilization layer and cover completely with the gravel? Also does anyone have a fire pit area with the gravel as I am wondering how loose it is and if you had any after thoughts? Thanks.
robstapp1985 is offline   Reply With Quote
Old 09-19-2017, 09:39 AM   #2
ZZZZZ's Avatar
Rewards Points: 2,314
Re: Advice on Fire Pit seating area
Here's my fire pit. Obviously not currently in use during the monsoon season here in AZ.
I've got a bit of crushed granite on top of a rough, sandy & rocky base.
In my area, pea gravel or slightly larger is a lot less expensive than river rock, if cost is a concern. River rock is prettier.
A base layer wouldn't hurt, but probably not necessary.
Large gravel probably not a good idea.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 09-19-2017, 05:27 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... Yer plan will work, not really necessary to dig, unless to fix/ alter drainage grades,....
Pea stone, crushed, washed, 'n graded from big rocks will eventually compact, 'n stabilize,...
A decent walkin' surface,... like ZZZZZ's appears to be,....
Loose round river rocks, Never compact, 'n Never stabilize, 'n make a poor walkin' surface in My mind,.... Mealy, no sure footin',...
Old 09-19-2017, 05:41 PM   #4
retired framer
Rewards Points: 20,438
What we call road mulch is a mix of 3/4 crushed and smaller right down to sand. It will pack down and give a stable walking area.
ClarenceBauer likes this.
Shed Foundation Advice - Southern Ontario Area SlashTG Building & Construction 3 06-15-2017 07:03 PM
Need Advice Reinforcing Storage Area. JaysLittleOcean Building & Construction 6 05-23-2016 12:23 AM
Need advice on decorating/furnishing living area atomicdev Interior Decorating 20 11-05-2014 02:36 AM
Installing floating wood floor, need advice on fixing uneven floorboards armand11 Flooring 0 05-06-2013 11:27 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
