Adding A New Valvebox Without A New Line - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2017, 03:20 PM   #1
Rewards Points: 24
Adding a new Valvebox without a new line
imgur.com/a/5tEau
really hoping i can do what is in the diagram but i suspect it wont work and will result in all valves in box 2 being turned on (which is what i don't want). Is there not an affordable device or even a new timer that can do what i'm trying to achieve?
I would think that creating variable resistance on the timer end of the shared conductor would allow a single conductor to be split at the box end to open an shut individual water valves (assuming i the colors are matched up end to end). There has to be a device , other then the doubler , that can do this for multiple connections
weekendscrub is offline   Reply With Quote
Old 05-31-2017, 03:58 PM   #2
Rewards Points: 24
Re: Adding a new Valvebox without a new line
Originally Posted by weekendscrub View Post
imgur.com/a/5tEau
here is the actual diagram, sorry about that
Old 05-31-2017, 04:00 PM   #3
Rewards Points: 24
[QUOTE=weekendscrub;4298729]here is the actual diagram, sorry about that
Old 05-31-2017, 08:00 PM   #4
Rewards Points: 17,912
Let us in one what it is your really trying to do.
The more info the better replys you'll get.
Old 05-31-2017, 09:47 PM   #5
Msradell's Avatar
Rewards Points: 818
There is nothing available that I know of they can do what you are trying to do. Every valve box is going to need a common (which can be shared) and every valve was going to need a separate wire coming from the controller to it to turn it on and off. What you want to do with something called multiplexing and it's done in high-end vehicles and industrial applications but it's very expensive and technology has not filtered down to systems such as this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 06-01-2017, 06:57 AM   #6
Rewards Points: 24
Thanks Joecaption. Basically just trying to use an existing sprinkler line instead of laying a new one
Old 06-01-2017, 06:59 AM   #7
Rewards Points: 24
Thanks msradell. That is helpful. you are keyed in on what i'm looking to do but I'm bummed that it is expensive ! thanks again
Old 06-01-2017, 08:11 AM   #8
Rewards Points: 24
msradell - after searching for 'multiplexing Sprinkler' i found this link with someone trying do do exactly what i'm trying to do
https://electronics.stackexchange.co...d-multiplexing but it is too bad the product they mention is no longer available!
Old 06-02-2017, 10:59 PM   #9
Msradell's Avatar
Rewards Points: 818
Doing a little further research it does look like RainBird makes a 2 wire system with smart modules. Here is a link to it. http://www.rainbird.com/landscape/pr...rs/ESP-LXD.htm
Don't know what the pricing is, I'm sure it's quite high but...
How to replace your clothes line Fantastic Remodeling 5 08-17-2013 09:17 AM
Main water line, meter to house ckc Plumbing 15 09-28-2012 09:15 PM
Adding drain line in basement floor - size and trap? theedudenator Plumbing 0 07-11-2011 09:22 PM
Adding basement supply's to trunk line emarlin HVAC 12 04-20-2010 11:42 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
