1 Gallon Water Bottles In Urn - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-07-2015, 09:29 PM   #1
Rewards Points: 850
1 gallon water bottles in urn
bought a couple of 36" tall urns. the woman at home depot garden section said i could put some 1 gallon water bottles in the bottom of the pot. full of water, seems like ill need 5 or 6 to get the bottom up to wear ill still have more than enough area for the mulch and dirt needed for the plant ill be putting in it. any else heard of doing this. how long will the bottles last before breaking apart.
hotrod351 is offline   Reply With Quote
Old 06-08-2015, 05:02 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... Til the water freezes, 'n expands bigger than the jugs,...
Old 06-08-2015, 05:32 AM   #3
Rewards Points: 17,914
That shape might work fine inside, your going to get sick of picking them up every time the wind blows them over no matter what you put in the bottom.
The base is just to small. I'd be using pea gravel for drainage and weight.
Colbyt (06-08-2015)
Old 06-08-2015, 05:44 AM   #4
Rewards Points: 850
well it weighs 100 pounds, with nothing in it.
Old 06-08-2015, 07:08 AM   #5
Rewards Points: 7,015
How much do you think a tree weights? They blow over.
If you already had the answer in your mind, why ask for an opinion. You got a good one from Joe.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 06-08-2015, 07:33 AM   #6
Rewards Points: 850
oh geeez, i asked a simple question and get a bunch of smart a++ answers. first of all it doesnt freeze here in bullhead city arizona, second i know all about the wind here, ive lived here for 30 years, and yes ive seen trees blow over, so maybe if i attach a few large butterfly wings to it, towards the top ofcourse, and put it in the middle of my yard with nothing blocking then wind, well then i could maybe watch it blow over, but in reality the weight of it plus the added weight of the dirt, thinking about 150 pounds, boy i guess my wife better not go outside in the wind or shell blow over. so neither of you know about the water jugs in the bottom of these large urns in the desert to take up space and even help keep the dirt a little cooler in the summer.
Old 06-08-2015, 09:18 AM   #7
Rewards Points: 1,568
Sure saved me money by giving up my subscription to the funny papers.
Old 06-08-2015, 12:00 PM   #8
concretemasonry's Avatar
Rewards Points: 2,716
Since you a in Bullhead City (great name!!!) and frost is not a problem, just putting water (not in jugs) plus some pea rock in the bottom to improve drainage and then add the soil of you choice. You are in an area where the natural evaporation is very high, so some watering is necessary.
If there small drainage hole in the bottom to remove the excess water?
The soil you put in will draw up the moisture for plants by capillary action and the roots will go down eventually to get water. Get a moisture probe from a garden supply to guide your watering. If you do not have a drainage hole, you can drown the roots of the plants.
Make sure you have the pot in its final location (be very sure) before filling. - Obviously!
Good luck.
Dick
concretemasonry is offline   Reply With Quote
Old 06-08-2015, 12:46 PM   #9
Location: SE Michigan, zone 5/6 depending on winter intensity
Rewards Points: 72
HotRod, your profile doesn't state your location, so other posters had no way of knowing. Their answers about freezing and other weather issues were general and appropriate.
As to the water bottles, I've been gardening since I was a child, but never used bottles of water in urns or containers. Actually, I wouldn't be too quick to rely on gardening advice from one of the big box stores.
I've used small pebbles as Joe suggested or broken crockery (especially broken clay pots), which allow water to drain through the urn and out the bottom, which is what you want. Otherwise, the roots could become waterlogged.
Given that your urn already weighs 100 pounds, you could avoid adding extra weight and create height at the same time by placing smaller clay pots upside down in the urn. That also allows you to just place another pot with flowers or foliage directly on top. It won't add as much to the weight as stones and chards.
Remember that different containers release moisture at different rates - the good old clay pots release much quicker than plastic, which tends to hold moisture. Styrofoam is right in the middle for moisture release time. I'm guessing that your urn is some type of clay with a finish over it. That finish might cause moisture release to be slower.
Just cautioning on this because some plants can't tolerate containers or urns that hold too much moisture. Begonias are in this category.
As to keeping the urn cool, I've never heard of using water bottles. I think the substance of which the urn is made, plus the obvious issues of sun/shade placement would make more of a difference.
NorthernWinds is offline   Reply With Quote
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Not Enough Hot water in the shower from a 40 Gallon Electric Hot Water Heater. rcake Plumbing 10 06-10-2011 12:20 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
