1/4 Acre Lawn: Ride On Mower Options? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By Bondo
  • 1 Post By Windows on Wash
  • 2 Post By lenaitch
  • 1 Post By Colbyt
Old 04-05-2017, 11:21 AM   #1
Rewards Points: 288
1/4 acre lawn: ride on mower options?
I have just over 1/4 of an acre of land. For the most part it's all open (no big trees).
I have a nice Honda push mower that does the trick: and by mulching I can get the yard done in about an hour.
My problem is the other tasks: Dethatching, aerating, etc... Sure they're only needed once or twice a year, but renting machines gets pricey and annoying (even when going in with neighbors).
Obviously I'd look like an idiot with a lawn tractor in such a small yard, but the attachments almost make sense for one.
So I'm curious: would a lawn tractor make sense? Or what do you all do for lawn care for smaller lawns?
gizzygone is offline   Reply With Quote
Old 04-05-2017, 11:43 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,320
Re: 1/4 acre lawn: ride on mower options?
Ayuh,.... I'm only 62, 'n still very active, so, Ya, you'd look pretty foolish to me,....
I don't do dethatching, aerating, etc...
I mow my lawn when it needs it, which is weekly from May through July, then the heat kicks in, 'n it rains less often, so every other week til late September,...
I also see No need to have a golf course lookin' lawn,...
In my world, anything that's green after I mow is good enough to call a Lawn,....
joecaption and callred like this.
Old 04-05-2017, 11:43 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,530
Not in my opinion. Unless you are talking the much higher end machines and implements (i.e. the CUT - compact utility tractors...not the riding mowers at HD and Lowes in this case), the job you will get with the rental equipment is much better.
Your standard riding lawn mower will not do any of those functions very well and if you get into the higher end machines, they are over 10K (well over) and the implements are in the thousands of dollars as well.
Bondo likes this.
Old 04-05-2017, 04:16 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,124
So long as you are physically able to use a push mower, I don't think a lawn tractor is worth it for a yard that size. As mentioned, the attachments and accessories are expensive and don't always perform as well as a dedicated machine from a rental and depending on the make, can be an unholy pain to install. Also, since you say it is "mostly open" you will still need the push mower for parts you can't get at with the tractor.
Bondo and joecaption like this.
lenaitch is offline   Reply With Quote
Old 04-05-2017, 05:08 PM   #5
Rewards Points: 6,953
I've mowed mine twice now and the last time last year was around Dec 10 (mostly to mulch the leaves).
I have not dethatched since I put a mulching blade on the Snapper. The yard has never been aerated in the 22 years I have lived here . I live on a gold course and the yard matches the surroundings.
I do have a rider for about half the yard you have. At the time I bought it I just did not have the energy to climb ladders all day and mow the grass with a push mower when I got home. The Snapper was the largest mower that would fit in the garage and still allow two cars to fit.
Buy a rider if you want. I suspect you will not be pleased with the results of the attachments. I think the neighbors are crazy to pay 40-50 $ a week to get theirs mowed so I really don't care that they think I'm crazy for owning a rider that paid for itself the first 3 years that I owned it.
callred likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Lawn mower starting issue syoung3765 Tractors & Mowers 2 07-24-2014 12:16 PM
Lawn mower starts then dies gazz87 Landscaping & Lawn Care 8 11-19-2011 01:43 PM
lawn mower engine races noquacks General DIY Discussions 9 06-10-2011 05:35 PM
Electric Lawn Mower Purchase Decision jasonnewyork Landscaping & Lawn Care 5 03-28-2011 06:22 AM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 02:37 PM
