Yellowed Polyurethane On Woodworking - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-28-2014, 04:04 PM   #1
yellowed polyurethane on woodworking
I have been remodeling a 1980's home, replacing all of the stained doors and trim with white. With most of the house updated to white tirm and doors, white outlets, white everything...the old staircase railings and banister stick out like a sore thumb. They are stained a light straw color, but have turned a yellow/orange over time. There is other miscellaneous carpenty in the house that is also yellow/orange tinted.
Aside from sanding everything down, re-staining, etc. I'm wondering if there are any tricks out there for "revitalizing" old polyurethane to remove the yellow/orange effect that has occured from light over time.
Thanks!
bmbigda is offline   Reply With Quote
Old 03-28-2014, 05:56 PM   #2
Retired Moderator
Rewards Points: 7,174
No way that I know of-----How would they look with a nice coat of paint?
Old 03-28-2014, 08:12 PM   #3
yea - that's my best case scenario right now...painting the individual balusters white, and staining the handrails and main balusters darker (after sanding). there are 60-ish balusters though. it's a wrap around railing that surrounds the entier 3rd floor.
Old 03-28-2014, 10:27 PM   #4
JUSTA MEMBER
Rewards Points: 3,624
You might try some automotive rubbing compound.
It takes a lot of elbow grease to use and I know that it removes the oxidized film from a cars finish without removing much of the paint underneath.
Then you could re polyurethane it to a nice sheen once more.
Just try it in a small test spot first, and if it works good. if not you are out the cost of a can and a couple of hours testing.
ED
de-nagorg is online now   Reply With Quote
Using Aerosol Polyurethane to finish doors? roxksears General DIY Discussions 4 11-07-2010 05:16 PM
The Woodworking & D.I.Y. Show in Dallas WoodworkingShow General DIY Discussions 0 10-08-2010 01:16 PM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 08:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
