Working Around A Window In 1940's Bungalow - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By joecaption
  • 1 Post By ChuckF.
Old 08-23-2018, 05:55 PM   #1
Rewards Points: 118
Working around a window in 1940's Bungalow
I have been slowly remodeling our 1940s bungalow, and I finally got the back bathroom. I ripped down to the studs, updated electricity and plumbing etc, but this is the first time I encountered a window in its original frame. (we had new windows installed almost everywhere else). The pictures below are what I have. The problem is, the frame for the window sits about 3/4" proud of the studs on the wall. The simple option is to shim out the studs 3/4" but that puts the wall even closer to the toilet than it already is. What are the other choices or am I stuck there?
Working around a window in 1940's Bungalow-20180823_183850.jpg   Working around a window in 1940's Bungalow-20180823_183901.jpg   Working around a window in 1940's Bungalow-20180823_183912.jpg
chrisb75 is offline   Reply With Quote
Old 08-23-2018, 06:40 PM   #2
Guapo
Rewards Points: 11,950
Re: Working around a window in 1940's Bungalow
After you install dry wall, there will be 1/4" for molding. What's the problem?
Guap0_ is offline   Reply With Quote
Old 08-23-2018, 06:43 PM   #3
Rewards Points: 118
The window frame will stick out 1/4 inch, how do I trim that out? Or the bottom for that matter? See where the Dado joint is?
I guess I don't understand how a 1/4" window frame sitting proud of the drywall isn't a problem.
Old 08-23-2018, 06:44 PM   #4
Rewards Points: 118
Old 08-23-2018, 06:45 PM   #5
retired framer
Rewards Points: 18,478
It was done that way for the thickness of the plaster. Cut strips of 1/4 plywood to add to the studs and plates, add 1/2 drywall and cover the wood with window trim.
chrisb75 likes this.
Old 08-23-2018, 06:54 PM   #6
Rewards Points: 118
Thanks, neat. That makes sense.
Old 08-23-2018, 07:18 PM   #7
Rewards Points: 17,884
1/4" plywood is fine but a whole lot easier to just use stips of 1/4 Lattice.
Make sure to add some spray foam in all those gaps around that window and fill under that sill.
Old 08-23-2018, 07:26 PM   #8
Rewards Points: 1,744
Two other ways to go if you don't want to build out the whole wall. You could customize your window trim molding with a rabbet about 1/4" x 1/4". Some styles may not be able to accomodate that kind of rabbet. Second, you could apply the 1/4" shim boards around the window, after sheerocking, as wide as would be covered by your standard window trim molding.
ChuckF. is online now   Reply With Quote
Old 08-23-2018, 07:28 PM   #9
Rewards Points: 118
Yeah I thought of that after Neal said 1/4". I can get lath at my HD and its 1/4" thick.
Just added the spray tonight after I took the pic. Thanks!
Old 08-23-2018, 07:33 PM   #10
retired framer
If you use lath, screw the drywall from the bottom up so the broken bits don't fall in between and make a bulge in the wall.
Old 08-24-2018, 02:27 PM   #11
Rewards Points: 426
After trying many of the suggestions above I have found (for me) the easiest thing to do is 2 layers of 3/8" drywall.
KC_Jones is offline   Reply With Quote
Old 08-28-2018, 11:02 AM   #12
Rewards Points: 118
I just used 1/4 lattice in 1 3/8" width. Worked great. Drywall is now flush with the window frame.
Working around a header above a bay window microscopes123 Building & Construction 13 08-02-2017 09:43 PM
How to remove old caulk in window sill with reduced working space? kkruecke Windows and Doors 6 07-21-2014 12:01 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
