Wood Paneling On Ceiling - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2014, 08:59 PM   #16
garlicbreath's Avatar
Rewards Points: 150
Where are you located? Reason I ask is that you may have better sources available. Better than lowes and hd.
Sent from my Motorola MicroTAC 9800X
garlicbreath is offline   Reply With Quote
Old 06-10-2014, 09:39 PM   #17
Rewards Points: 54
I'm in northern Ohio. I'm honestly not too well versed with anywhere around here outside the big boxes.
How about using unfinished hardwood flooring? Any disadvantages there?
eagle3ye is offline   Reply With Quote
Old 06-10-2014, 09:55 PM   #18
Rewards Points: 150
http://woodfinder.com
so so search engine.
Old 06-11-2014, 09:01 AM   #19
Rob
Robpo's Avatar
Rewards Points: 826
Originally Posted by eagle3ye View Post
That looks gorgeous. I've been leaning toward going with the exact same thing. I also found another set of unfinished panels that would cost about $100 less than the tongue and groove I was looking at.
http://www.lowes.com/pd_409414-1487-...=#BVRRWidgetID
I'm guessing the big disadvantage of not having the tongue and groove is gaps appearing from expansion and contraction. How worried should I be about this?
I think the problem with that is no tongue and groove on ends. It would be ok if the room was 8' wide or you had a beam or something at 8'. If you could break the room into 4 or 8' sections it would be ok.
Robpo is offline   Reply With Quote
Staining to match discolored wood tongue and groove ceiling DIY808 Painting 7 03-10-2015 09:48 PM
Covering unusual ceiling with wood Louie D Building & Construction 3 05-21-2013 05:44 PM
Tiling Over Painted Wood Paneling for Wood Stove Insert MegMarkR1 Tiling, ceramics, marble 2 02-07-2012 11:45 AM
Can I put old removed wood paneling over joist in attic timmay_8 Building & Construction 6 12-15-2011 02:40 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
