Wood Paneling On Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-10-2014, 09:59 AM
Rewards Points: 54
Wood Paneling on Ceiling
Hello,
I want to replace a textured drywall ceiling in my den with some kind of wood paneling. I've found a lot of different products that appear would work pretty well. I'm leaning towards a stainable tongue and groove panel (8" x 12'). Does anyone know if this would work well? Is there something else that might work better?
Also, will I be required to remove the existing drywall ceiling? I'd rather not as the rest of the room is finished and the dust storm produced by falling sheetrock is something I'd like to avoid.
Thanks.
eagle3ye is offline
Old 06-10-2014, 10:05 AM
garlicbreath's Avatar
Rewards Points: 150
When I demo'd my house I gave all my t&g knotty pine to a friend. He then pit it on his ceiling and he boxed a beam with it. It looks great. Did he go over drywall? Not sure.
That would be up to you whether to go over or tear out and how deep you want to go down the rabbit hole.
Sent from my Motorola MicroTAC 9800X
garlicbreath is offline
Old 06-10-2014, 10:13 AM
Rewards Points: 54
Lol my thoughts exactly. The room is pretty big (275 sq ft) and there's only two spot lights at the far end of the room over the fireplace. This meant using lots of floor lamps than never seemed to get the room bright enough. I'm planning on replacing those two spot lights with some recessed can lights and possibly two ceiling fans on opposite sides of the room. I'll also be adding speaker wire, new ceiling outlets (for a mounted projector), and some HDMI ports. As you can see, there will already be some drywall demo involved here, but I'd like to keep it under control and isolated if possible.
I'm actually planning on boxing with crossbeams as well. The wood paneling in the room is painted black, so I'm going to go with the same color on the beams. Should look sharp.
eagle3ye is offline
Old 06-10-2014, 11:55 AM
Rob
Robpo's Avatar
Rewards Points: 826
Originally Posted by eagle3ye View Post
Hello,
Thanks.
Personally I would run 1x4"s perpendicular to the direction you want the ceiling to go, over the existing and go.
Robpo is offline
Old 06-10-2014, 12:23 PM
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I can't imagine why that would be !!!
Black walls is always a good idea...in a morgue or the Bat Cave!
I doubt that adding more can lights will change anything, especially if faux-beams are also to be added.
Any-hoo...Take a look at a tongue and groove product known as "car-siding", you might like it. I think it also comes with a lap-feature. The name comes from the product being used on railroad cars years ago.
XXX
Bud Cline is offline
Old 06-10-2014, 01:02 PM
JUSTA MEMBER
Rewards Points: 3,556
To hang paneling on the ceiling you need to build framing up there so it can be supported every 16.5 " , which just covers up ypur old stuff well. And will give you ample opportunity to run wiring for new lighting, sound system, etc.
ED
de-nagorg is offline
The Following 2 Users Say Thank You to de-nagorg For This Useful Post:
Bud Cline (06-10-2014), eagle3ye (06-10-2014)
Old 06-10-2014, 02:41 PM
Rewards Points: 54
Lol, the paneling is newly installed - it only covers the bottom third of the wall. ;-)
ED
How would you suggest I go about building the frame? Should I screw in 1x4's every 16.5" perpendicular to the joists as suggested by Robpo? Also, would 2" finish nails be sufficient to hold the paneling to the frame?
Thanks a lot.
eagle3ye is offline
Old 06-10-2014, 02:48 PM
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thanks a lot.
You keep referring to this ceiling product as "paneling".
Are you in fact using "paneling" such as paneling that comes in 4'X8' sheets? If so, you should have cross-overs (to suite your layout) in addition to your joist-matches.
XXX
Old 06-10-2014, 03:01 PM
Rob
Robpo's Avatar
Rewards Points: 826
I think screws would be better especially if planking is heavy.2 1/4" or 2 1/2" better. Yes if planking is parallel to joists every 16" ,19.2" or 2' what ever yours run.
Robpo is offline
Old 06-10-2014, 03:04 PM
Rewards Points: 54
Honestly, I haven't made up my mind yet on the 4'x8' paneling sheets or narrower 4"-8"x8'-12' tongue and groove panels. That was the second part of my original question actually. What would be appropriate for ceilings?
eagle3ye is offline
Old 06-10-2014, 03:10 PM
JUSTA MEMBER
1X material will give you barely enough room to install wiring for lights, I might use 2X material instead, depending on how many lights I would want to install. And the sizes of the junction boxes I want to use.
Screwing the boards to the ceiling is good if you can hit every joist. Then stagger your 8" x 12' paneling so that you do not have any side by side butt joints.
Or if you get side by side butt joints cover them with a trim piece. As they are UGLY most of the time.
ED
Old 06-10-2014, 06:15 PM
Rob
Robpo's Avatar
Rewards Points: 826
I used 1x6"x12' with 2x4"perpindicular to trusses, two 3 inch common/sinkers every 2 feet. I random staggered all seems.
Robpo is offline
The Following 2 Users Say Thank You to Robpo For This Useful Post:
de-nagorg (06-10-2014), garlicbreath (06-10-2014)
Old 06-10-2014, 06:47 PM
Retired Moderator
Rewards Points: 7,174
Check your local code---here we must have drywall behind wood paneling or car siding on ceilings--as a fire stop.
oh'mike is offline
Old 06-10-2014, 07:17 PM
Rob
Robpo's Avatar
Rewards Points: 826
car siding is my ceiling. That is all I can get where I live. I had to put a "foil on one side paper on other" up first.
Robpo is offline
Old 06-10-2014, 08:52 PM
Rewards Points: 54
Originally Posted by Robpo View Post
Attachment 85888
That looks gorgeous. I've been leaning toward going with the exact same thing. I also found another set of unfinished panels that would cost about $100 less than the tongue and groove I was looking at.
http://www.lowes.com/pd_409414-1487-...=#BVRRWidgetID
I'm guessing the big disadvantage of not having the tongue and groove is gaps appearing from expansion and contraction. How worried should I be about this?
eagle3ye is offline
Staining to match discolored wood tongue and groove ceiling DIY808 Painting 7 03-10-2015 09:48 PM
Covering unusual ceiling with wood Louie D Building & Construction 3 05-21-2013 05:44 PM
Tiling Over Painted Wood Paneling for Wood Stove Insert MegMarkR1 Tiling, ceramics, marble 2 02-07-2012 11:45 AM
Can I put old removed wood paneling over joist in attic timmay_8 Building & Construction 6 12-15-2011 02:40 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
