Window Screen Material Construction Help - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-04-2015, 09:28 AM   #1
Rewards Points: 752
I am building window screens for a built in porch on my home. I need some cross beam material that keep the aluminum screen material from bowing when the screen is installed on the frame. What do you call the cross beam material?
I'm assuming that the cross beams are held onto the screen frames with some sort of clips(also don't know the name) that, also assuming, go into the channel of the frame before installing the screen and spline? Thanks!
kennykenny is offline   Reply With Quote
New Construction Window Bow/warp. Help typer0186 Windows and Doors 5 06-14-2012 10:59 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
