Window In A Load Bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-08-2016, 01:25 PM   #1
Rewards Points: 38
Window in a load bearing wall
Hi,
I am considering making a window/picture cutout as shown in the image in a load bearing wall. This wall is between kitchen and the living room and it is on the first floor. Since there is one story below this floor(basement). what sort of support
do I need once I have removed 3 studs and replaced it with a header. I understand that now header will transfer the load
on the sides and the load now on each sides(2 thick red arrow in the picture) will be more than what was before since we replace 3 stud where load was equally supported by all existing studs.
[IMG][/IMG]
http://postimg.org/image/sraercgod/
http://s30.postimg.org/xpxx5vkhd/Wal...es_233x300.png
So in order to compensate, Do I need to provide 2 more post to support in the basement. and if so do I need to dig the concrete floor in the basement to install these 2 supporting post.
Esentially the load remains the same on this wall but by making this sturctural changes I am creating 2 point loads at ends which is different that exisitng wall load distribution where the the load was distributed equally on each stud.
diychat09 is offline   Reply With Quote
Old 03-08-2016, 01:45 PM   #2
Rewards Points: 1,602
I'm not an expert, but adding a window into a wall will not make you need footings under the point loads. That's more for when you tear out the entire wall and add a great deal of weight at the ends of a large beam. I think you should be fine.
mikegp is offline   Reply With Quote
Old 03-08-2016, 06:08 PM   #3
Rewards Points: 38
Any other suggestions?
Old 03-08-2016, 06:31 PM   #4
Retired Moderator
Rewards Points: 7,174
You will be fine---I usually add a 2x10 or 2x12 double as a header--that is over kill for a small opening---but it is what I do--saves time--easier to keep the wall flush and it is plenty strong.
Old 03-08-2016, 08:27 PM   #5
Registered User
Rewards Points: 526
Make the window top same elevation as the other house windows, if possible. IF a TJI floor joist system, you will need point-load blocking at the rim joist. Your local AHJ may want to advise as this is a "structural" change... give them a call to be safe. Appears to be under a six foot wide window, doubt you need blocking, depends on the snow load per location...http://publicecodes.cyberregs.com/ic...9_5_par024.htm
Gary
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Load Bearing wall? ssgtjoenunez Building & Construction 12 03-01-2013 06:03 PM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 11:29 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
