Whole Home Texture Removal - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2019, 09:58 PM   #16
Rewards Points: 484
Re: Whole Home Texture Removal
In a residential situation no one would have been using asbestos in the popcorn. Asbestos pops up in old schools and the like for fire protection.
I used a 2 gallon garden sprayer and wet down a 3x3 section of the popcorn and then took a special scraper (long handle taping knife used for mud on drywall) to knock it down into a plastic garbage bag. It went very quickly and was a dust free process.
One caveat - popcorn was usually done as a way to cover the seams of drywall on ceilings where an unskilled person did the mudding. I had to fix some of the seams on my ceilings after removing the popcorn with the application of joint compound which I then sanded.
Calson is offline   Reply With Quote
Old 01-24-2019, 05:20 AM   #17
retired painter
Rewards Points: 1,370
Not true! While asbestos popcorn was often specified for commercial work it wasn't uncommon for it to be used in residential too especially if the same company was doing both types of work. As an employee I've sprayed asbestos on residential ceilings back in the early 70s.
mark sr is offline   Reply With Quote
Old 01-24-2019, 06:04 AM   #18
Mystriss's Avatar
Rewards Points: 3,100
I've heard from multiple sources (on the internet so take that with a grain of salt) that once a popcorn ceiling has been painted it's nigh impossible to scrape it off without damaging the drywall underneath.
I am pondering doing some hands-on testing of this when I gut and soundproof my studio (hopefully this spring/summer.)
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 01-24-2019, 06:11 AM   #19
retired painter
Painted popcorn is a lot harder to remove. Popcorn is water soluble but if the water can't reach it ..... on painted popcorn I'll scrape if first, that exposes a portion of the bare popcorn. You can then mist the ceiling with water and the scraped off tips will soak up the water aiding in scraping off the rest of the texture.
Tags
lathe , popcorn ceiling , texture
Home remodeling help needed, just bought first home rrmsca Remodeling 6 06-05-2018 11:05 AM
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 08:03 PM
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
Need a Barn home forum?? And or suggestions from here? also need plan ideas? software RUMBLON General DIY Discussions 11 01-17-2011 12:33 PM
