What Type Of Tape For Indoor Plastic Dust Protection Sheeting? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By TonyNYC
Old 07-26-2016, 03:16 PM   #1
Rewards Points: 6
What Type of Tape for Indoor Plastic Dust Protection Sheeting?
I am about to completely demolish 2 bathrooms, down to the studs. It's an old house with plaster walls and doing so will make a huge mess with plenty of dust.
So, I grabbed some zipper doors as well as 100' of 6 mil plastic sheeting, and I'd like to make a 20' long plastic tunnel between the bathroom and the front door.
I need to find 2 types of tape to serve 2 purposes.
1) The best tape to join the 6 mil plastic sheeting to itself.
2) The best tape to join the 6 mil plastic sheeting to my walls (preferably without removing all the paint.
Any recommendations would be really appreciated.
For the first purpose, I went on Amazon and it seems that sheathing tape might serve as a great way to to join the plastic sheeting to itself, but horribly to tape sheeting to walls. The stuff I'm eyeballing is called InterTape, 5936USW Sheathing Tape.
TonyNYC is offline   Reply With Quote
Old 07-26-2016, 03:44 PM   #2
JUSTA MEMBER
Rewards Points: 3,576
Re: What Type of Tape for Indoor Plastic Dust Protection Sheeting?
Try Blue Painters tape, it is designed to tape walls and not pull the old paint off when removed.
ED
de-nagorg is online now   Reply With Quote
Old 07-31-2016, 09:12 AM   #3
Rewards Points: 2,458
I used 3M blue painter's tape for many yrs. It works so didn't compare costs. I've seen Intertape brand but unless significantly cheaper, wouldn't risk it. 3M can stay on old flat (semi or gloss is even better) paint for months and come off without leaving glue or taking a paint chip with it. Where it's yrs, it may take paint (computer cable). But if your paint is bad enough that it's separated (water damage, near the steam radiators, etc), nothing will help.
I think the 3M blue has gotten thinner so needs to be gentler with it.
carpdad is offline   Reply With Quote
Old 08-11-2016, 06:37 AM   #4
Rewards Points: 16
The green FrogTape is what I use for work. No issues with it and can be kept on painted surfaces the longest. They also make a yellow tape which is for very delicate surfaces, but I wouldn't use the yellow for taping sheets together. For that I would just use cheap masking tape.
Lemontwist is offline   Reply With Quote
Old 08-12-2016, 12:24 AM   #5
Rewards Points: 12
I would take two 2x4s and cut them exactly from floor to ceiling. Use wood shims under 2x4s at floor to secure them in place also put a 2x4 top and bottom to make a frame then you can use duct tape to hold blue tape will not hold 6 mil plastic especially when you in and out trust me from experience
Good luck!
Sawyer10702 is offline   Reply With Quote
Old 08-12-2016, 12:25 AM   #6
Rewards Points: 12
Good luck!
Oh and use the blue tape to seal 2x4 s to wall.
Old 08-15-2016, 07:59 AM   #7
Rewards Points: 6
Thanks for the help fellas! Here are a few 360 photos of the protection I laid around the house. Did not go for the full plastic tunnel, but this solution served me well:
de-nagorg likes this.
Tags
demolition , dust protection
What type of hearing protection for jackhammer? Ultrarunner2017 Safety 6 07-22-2015 11:30 AM
But joint mesh pops in primer sxotty Drywall & Plaster 15 03-27-2013 07:59 AM
What kind of surge protector to get for these items baby327nd Electrical 27 10-06-2011 03:35 PM
Wrong type of Joint Compound or Tape bigwill Drywall & Plaster 5 05-18-2011 11:30 AM
