DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Remodeling (https://www.diychatroom.com/f15/)
-   -   What style of drawer is this? (https://www.diychatroom.com/f15/what-style-drawer-439898/)
DIYHero 10-19-2016 09:08 AM
1 Attachment(s)
Hello all,
I am refinishing some old cabinets, but the drawers had the slide mechanism shown below. Ive been poking around online but am unable to come up with what this style is called. Any ideas?
I wanted to replace them, but the sizing of the drawers is off, and im looking at a laborious and untested approached of gluing 1/8 inch pieces to the sides to accomodate more modern drawer pulls. Id tossed some of the old ones unthinkingly.
Any help is appreciated, thank you!
carpdad 10-20-2016 07:27 AM
Re: What style of drawer is this?
That must be ikea and if it is you may be out of luck. Not that my experience is extensive but all slides were 1/2" clearance for the side installs. That means you need half inch between the install frame and the drawer frame. I don't know but search low clearance or 1/4-less than 1/2" (any number between) drawer slides. It is possible to make them. Plastic wheels are available for bifold doors and such. The wheels need to fit into the track on the drawers.
DIYHero 10-20-2016 07:58 PM
I dunno, their old and not very good quality, but i they're staid enough where i dont think they're ikea.
hkstroud 10-20-2016 08:31 PM
Seriously doubt that you will ever find matching draw guides.
Rather than adding 1/8" to each side of the draws I suggest that you add 1/8" strips to the sides of the frame. Reducing the size of the opening by 1/4". You could use some 1/4" Luan which is really only 3/32" thick. Might have to do a little sanding to get down to 1/8", but you are only sanding small strips.
Luan is also cheap.
Don't understand what your problem has to do with changing draw pulls.
DIYHero 10-20-2016 09:28 PM
Luan is also cheap.
these babies are floating, i dont think i cant add to the sides.
youre right re "pulls". my jargon is way off. i mean these drawers parts that support a track for drawers that pull out.
hkstroud 10-20-2016 10:39 PM
Don't understand. If you can add to the sides of the drawer and expand their width to fit the opening, logic says you could add material to the width of the opening to reduce its size to fit the drawer.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
