What Should I Use - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-06-2016, 12:00 AM   #1
Rewards Points: 6
What should i use
I'm remodeling my walls in my living room, i'm replacing the sheetrock with 1x8 knotty pine tongue n groove boards. I would like to know if I should install some type of backing on the wall before I install the knotty pine boards. If so what would you recommend?
MARLEA is offline   Reply With Quote
Old 12-06-2016, 04:58 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,274
Re: What should i use
So you want to remove the drywall?
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 12-06-2016, 08:38 AM   #3
Rewards Points: 2,464
Horizontal, vertical? If vertical, horizontal strapping on the wall for nailers. Definitely vapor barrier, minimum. All walls because you don't want leaky air movement even in the inside walls. Use house wraps that stops moisture and close around nails.
carpdad is offline   Reply With Quote
Old 12-06-2016, 08:46 AM   #4
Rewards Points: 17,890
Why remove the drywall?
I'd leave it.
Old 12-06-2016, 09:14 AM   #5
123pugsy's Avatar
Strapping on the walls plus the boards would be 1-1/2".
Big problems at doors and windows.
Using construction adhesive right on the drywall would be 3/4". Back band applied to door and window casings may help because the base board is now going to be 1-1/2" out from the drywall.
Old 12-06-2016, 09:33 AM   #6
Rewards Points: 6
i'm removing the drywall to install better insulation
The Following User Says Thank You to MARLEA For This Useful Post:
freddyream (12-16-2016)
Old 12-06-2016, 09:34 AM   #7
Rewards Points: 6
horizontal
Old 12-06-2016, 11:45 AM   #8
123pugsy's Avatar
Excellent. Just nail them to the studs.
