What To Put On The Back Of Kitchen Cabinets????? HELP! - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-12-2014, 06:14 PM   #1
What to put on the back of kitchen cabinets????? HELP!
I just put in new kitchen cabinets and I have base cabinets that come out like a peninsula so they are not up against anything, now what do I put on the back of them? I have looked all over the internet and can not find any kind of answer I bought the side pieces to put on the back but it's impossible to get the seamless or so they don't bow out I'm just at a total loss.
Jmilks is offline   Reply With Quote
Old 11-12-2014, 06:40 PM   #2
Rewards Points: 107
What are the cabinets made off and how are they finished? You can get furniture quality plywood in maple and birch. Cut and finish to match. You won't find the wood at a big box store , you will need to find a lumber yard that caters to cabinet and furniture makers.
jimn01 is offline   Reply With Quote
Old 11-12-2014, 06:47 PM   #3
Master Electrician/Owner
Jrannis's Avatar
Rewards Points: 128
I rocked mine and put ledge stone over that. Nice strip LED under the countertop washing light on it.
Looks very nice.
Jrannis is offline   Reply With Quote
Old 11-12-2014, 06:51 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
For example: http://homedepotpurebond.com/
XXX
Old 11-12-2014, 08:34 PM   #5
I bought the unfinished kitchen cabinets from Home Depot would you just cut them to size and screw them on the back?
Old 11-12-2014, 09:55 PM   #6
Rewards Points: 105
I would use the 4x8 beadboard paneling. Either liquid nail or contact cement to attach it. They also have paneling glue I believe. I would have also put the paneling on the end cabinet. Would coordinate nicely, IMO.
MaineLL is offline   Reply With Quote
Old 11-12-2014, 10:39 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Glue and pins/brads basically.
XXX
Old 11-13-2014, 03:27 AM   #8
Thank you
Old 11-14-2014, 10:39 AM   #9
Rewards Points: 4,146
In this video Ron shows you how to do it.
http://www.ronhazelton.com/projects/...kitchen_island
ron45 is offline   Reply With Quote
Old 11-15-2014, 09:37 AM   #10
Bill Kearney
Rewards Points: 1,174
It's common to build a pony wall behind the cabinets and finish that. Our 10' island has the plumbing in that wall. The outward facing side under the counter we could finish with either the cabinet wood or drywall. I chose drywall because I really didn't want to have the kids kicking $2k worth of mahogany panels. Yeesh, do they charge a pretty penny for custom cabinets...
But you'd need to factor the depth of the wall in the calculations for the counter above. The additional benefit is the wall also helps carry the load of whatever counter material you're using.
-- Bill
wkearney99 is offline   Reply With Quote
Old 11-20-2014, 11:35 PM   #11
Helioscribe's Avatar
I had a similar situation and wanted a simple clean look, so I decided to use 1/2" plywood with birch veneer attached directly to the back of the cabinets. I finished and protected the corners with 1/2"x1/2" maple.
Helioscribe is offline   Reply With Quote
The Following User Says Thank You to Helioscribe For This Useful Post:
tylernt (12-19-2014)
Tags
base , cabinets , ideas , kitchen , new cabinets
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 69 08-13-2017 06:02 AM
ceiling/wall slanting over kitchen cabinets fdf Remodeling 8 02-26-2012 02:52 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
