What Is This Part Of The Stair Called? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-18-2016, 07:22 PM   #1
Rewards Points: 34
What is this part of the stair called?
I've searched for "stair rail base" and the stair section of the hardware store. No luck. Need to replaced a small section that split.
untilcomplete is offline   Reply With Quote
Old 02-18-2016, 07:31 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
I think its called a shoe rail...but yours looks custom made from oak..
WhatRnsdownhill is offline   Reply With Quote
Old 02-19-2016, 08:28 AM   #3
Rewards Points: 144
http://me360e.com/stair-rail-components.html
mako1 is offline   Reply With Quote
Old 02-19-2016, 01:24 PM   #4
Rewards Points: 2,472
I don't think there is a name for it, unless used by carpenters in california or by an architect. The balusters are almost always on the stringers or on the treads.
It is just a finish grade lumber. Some split wood can be repaired. If you have the work room, a butterfly joint is one decorative repair. The balusters can be reinforced with longer nails that bite into the frame. Predrill first.
carpdad is offline   Reply With Quote
Looking for a part # or name Lennox LF24 chrizg HVAC 5 10-19-2012 04:42 AM
Replacement Part - What is it Called Ada01 General DIY Discussions 4 12-15-2011 03:30 PM
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 05:54 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 07:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 01:31 PM
