Want To Widen Kitchen Doorway. - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By Carloscda
  • 1 Post By Nealtw
Old 09-09-2018, 12:26 PM   #1
Rewards Points: 247
Want to widen kitchen doorway.
The doorway is 30in want to widen to 34in.
So the question is how to make the Header for this?
Thanks in advanced!
Carloscda is offline   Reply With Quote
Old 09-09-2018, 02:00 PM   #2
retired painter
Rewards Points: 1,352
Re: Want to widen kitchen doorway.
Have you verified whether or not it's a load bearing wall? what is above that wall?
mark sr is offline   Reply With Quote
Old 09-09-2018, 03:28 PM   #3
Rewards Points: 247
The doorway is below the second floor doorway.
The header thats in place now is a 2x3 with looks like a 1x3 in back of it.
The studs are 2x3 as well. Now above the header it looks like just a 1x3.
Old 09-09-2018, 06:29 PM   #4
Rewards Points: 17,890
Can you post a picture so we can see what your seeing?
None of those sizes sounds right to me.
Old 09-09-2018, 09:04 PM   #5
JUSTA MEMBER
Rewards Points: 3,574
Yes your dimensions sound odd.
Can you add a location to your profile page?
This will always be displayed to the left of your posts, like mine and the others, and will answer the question " Are you in the U S A with our dimensions, or somewhere where the dimensions are odd to us.
Still need to see what you see, so that we might understand.
ED
de-nagorg is offline   Reply With Quote
Old 09-10-2018, 04:27 PM   #6
Rewards Points: 247
Ok so after a closer look this would be more trouble than what it's worth just for 4 extra inches.
The cripples are 2x3's along with the header and studs.
Old 09-10-2018, 10:29 PM   #7
JUSTA MEMBER
Thank you for the location addition.
The simplest way to make a header for that, is to dismantle each side of the door, add a temporary stud there to support the top plate temporarily, while rebuilding the doorway, with new King studs, and jack studs, cut to accommodate a 2X whatever the dimension is for the height of the space between the top of the door jamb and the top plate.
Then also use 2 -1X the dimension, all screwed and glued in a sandwich to form a header that fits your space, this header is supported by the jack studs framing the doorway.
The header is 1.5 inches + 3/4inches +3/4 inches = 3 inches thick.
Your dimensions are odd to us because the building in Philly, is probably very old, built before dimensions were standardized.
Yes this is a lot of work, but anything worthwhile takes the effort to accomplish it.
Any confusion, don't hesitate to ask.
ED
Old 09-11-2018, 03:45 AM   #8
retired framer
Rewards Points: 18,500
ED
Ed; 3 inches will take a 2 ply header.
Older doors are 78" anything new will be 80" so you will want to check that and correct the height too.
for a 34" door you want a 36" rough opening and a 39" header.
I would build the header out of 2x6 or 2x8 and measure the height of the door before I decides on a height., some where between 82 and 83 unless it is outswing which is less.
You will have to rip new 2x4 studs down to fit in the 3"
Things take time to settle so if you can do this in one morning I wouldn't worry about holding anything up while you do it.
If you can selvage 2 old studs for the jacks you could get away with 2x3s for the king studs.
Old 09-11-2018, 06:52 AM   #9
JUSTA MEMBER
Yes they can use 2 - 1.5 inch as a double header. no problem.
ED
Old 09-11-2018, 06:54 PM   #10
Rewards Points: 247
Thank you for your detailed information!
I'll be remodeling my kitchen so I might still widen the door.
de-nagorg and Mike Milam like this.
The Following User Says Thank You to Carloscda For This Useful Post:
de-nagorg (09-11-2018)
Old 09-11-2018, 09:51 PM   #11
romeojk27's Avatar
Rewards Points: 14
I know in older homes there are doorways between kitchens and living areas, are you widen the doorway between the living room and kitchen?
If so, can I ask why not widen it more and not put a door in?
romeojk27 is offline   Reply With Quote
Old 09-11-2018, 10:46 PM   #12
retired framer
If it is not a load bearing wall you do not need a header.
Old 09-14-2018, 05:08 PM   #13
Rewards Points: 247
Don't know if its load bearing? The floor above the doorway & wall is in the same location.
Yes it's the doorway between the kitchen & dinning room. Use to be a swinging door there. Thought about widen it so I wouldn't have to go threw taking the doors off my fridge.
Hmm now that I wrote that it sounds kinda lazy lol
Old 09-14-2018, 05:37 PM   #14
retired framer
A dedicated DIYer will always find things to fix needed or not.
de-nagorg likes this.
relocating, widening doorway and pass-thru window in supporting wall NWVintage Carpentry 5 02-02-2013 01:25 AM
Kitchen floor tiles. ABurch Kitchen & Bath Remodeling 1 12-06-2012 12:35 PM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Needing to widen doorway...help! dgallagher Remodeling 13 10-30-2009 07:18 PM
Widen a doorway Oilerz Remodeling 3 01-06-2008 08:31 PM
