Wallpaper Replacement - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-18-2016, 01:34 PM   #1
Rewards Points: 322
wallpaper replacement
When replacing wallpaper, is it necessary to completely strip the old paste?
I am finding it difficult to clean it off completely. Hot water softens the paste but it is taking lots of wiping to remove only a little. Since it is stuck on there pretty good, can't I just add the new paste on top?
tns1 is offline   Reply With Quote
Old 07-18-2016, 01:46 PM   #2
47_47's Avatar
Rewards Points: 320
Re: wallpaper replacement
The old paste will telegraph through your new wallpaper and I'd remove it. Try a little vinegar mixed with your hot water and use a 6" putty knife to scrape it.
47_47 is offline   Reply With Quote
Old 07-18-2016, 03:05 PM   #3
Rewards Points: 4,094
Ugh. You're going through the work of removing the worst stuff in the world, can't you call it a win and paint instead of putting up more of it?
stick\shift is offline   Reply With Quote
Old 07-18-2016, 05:45 PM   #4
Rewards Points: 322
The situation is the wall is an ugly spatter texture underneath. I am not removing that. The wall paper itself was textured, which hid any irregularities.
Painting:
Either place new sheetrock or
Strip off all the paste,
Smooth over the old texture or re-texture,
Mask,
Prime,
Paint
Repapering:
Knock down the high points with a scraper,
Apply paste,
Repaper
Painting seems like hours of more work here. The only question is if new paste ever has a problem sticking to old paste. The old paste is really on there so it isn't failing anytime soon.
Old 07-19-2016, 01:39 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 32
Hey now, you are talking about my livelihood here. If applied properly all wall paper could be EASILY removed. All it takes it a proper wall covering primer first, that's all.
Old 07-19-2016, 01:42 AM   #6
chrisn's Avatar
Rewards Points: 32
Painting:
Mask,
Prime,
Paint
Repapering:
Apply paste,
Repaper
You can certainly paper over the old paste, it's done all the time in commercial situations. As mentioned it could telegraph through the new paper depending on what it is. The new paste will stick just fine.
Mold Behind Wallpaper - Remediation TheSrProgrammer Drywall & Plaster 25 03-13-2016 10:36 PM
Zinsser Gardz over skim coat over wallpaper adhesive? boilerturf Painting 9 02-02-2015 10:14 AM
Painting over wallpaper - no other option - How to proceed kuj0317 Painting 15 07-25-2011 04:25 AM
Wallpaper removal or primer? Should I put up new wallpaper instead? Aqua Painting 1 04-06-2011 04:36 AM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
