Wall Covering With Mesh Backing??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-03-2016, 04:00 PM   #1
Rewards Points: 20
Wall covering with mesh backing???
Hello. I recently realized that my kitchen is entirely wallpapered with a strange material. I was trying to research but didn't know what to search. None of the wall coverings mentioned were what's on my wall. It's a thick kind of cardstock-like almost wallpaper, but it's attached to the wall with like a thread mesh or netting. It looks like gauze or cheese cloth (little more durable or rigid however). Anyone know what it is? It comes off fairly easy but if it rips unclean from the wall, it is a PAIN to try and get the strings all off.
And it isn't stringy on the outside, only what is behind the wallpaper and attached to the wall- so it's not like the seventies thread wallpaper.
jessicurr is offline   Reply With Quote
Old 02-03-2016, 04:20 PM   #2
Rewards Points: 17,882
How old is the house?
Plaster walls?
Several company's sell a fiber mat to go over old failing plaster walls.
jessicurr (02-03-2016)
Old 02-03-2016, 04:26 PM   #3
Rewards Points: 20
It was built in '53. I don't believe it is plaster, just dry wall. The rest of the home is drywall. In any case, it appears to be in good shape. I was just curious since I couldn't find anything on the internet. And also thought it was weird because there was wallpaper over that covering too.
Tags
kitchen , remodel , wall coverings , wallpaper
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 01:35 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
