Wall Bearing Wall Removal / Pass Through - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jlhaslip
Old 03-23-2018, 11:44 AM   #1
Rewards Points: 26
Wall bearing wall removal / pass through
I have a 10 foot wall in between my kitchen and living room that is holding the third floor joists. I would ideally remove it completely or at least do a large pass though with bar top and seating.
Im curious as to how much weight this wall actually has on it. above the kitchen, to one side, is two full bathrooms, with the joists spanning 12 ft. To the other side is a bedroom with the joists spanning 12 ft as well.
Thing is. on the first level, there is no wall underneath this wall.
no interior walls are supporting any of the weight of the roof.
Are there any reasonable options to accomplish what I hope to?
What other info would be needed to figure this out?
jaigordon87 is offline   Reply With Quote
Old 03-23-2018, 12:19 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Wall bearing wall removal / pass through
That wall is carrying a minimum of (the length of the beam) times (half of the joist length) times (the specified floor load) plus any roof load which can be determined by an inspection of the attic.
So, 10 feet time 12 feet is 120 square feet at 55 lbs per foot. (40 lb Live and 15 Dead) Plus any floor load which we don't see based on your details. ie: trussed roof would be zero, stick framed roof would be considerably more.
Adds up to 6600 lbs + roof loading.
The best that can be done is to get an Engineer or competent Framer to inspect the situation on site.
There may be a structural beam in the Floor system which is carrying the load to ground. We also can not see that.
Mike Milam likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-09-2018, 03:59 AM   #3
Rewards Points: 12
I had a similar issue last year. I busted my head about it for a while, but then I decided to rely on one of the architecture firms in Melbourne, since that's where I live, of course. But I am sure you can find professionals in your area.
I ended up removing the entire wall that separated the kitchen and living room, because it wasn't one of the main walls, luckily. Now I have a magnificent open kitchen!
However, if that's not possible with you, you can bust big enough pass, of course, but it's best to check with your local professionals.
UforUserName is offline   Reply With Quote
Old 04-09-2018, 07:20 AM   #4
retired framer
Rewards Points: 18,464
You will find a beam in the floor below the wall, could be a flush beam that can not be seen with out some digging. Duplicating that beam and bearing posts will be a winner.
purlin supports/ Load bearing wall removal trlmix Remodeling 3 04-02-2017 07:45 PM
Need help with load bearing wall removal... Huggins90 Building & Construction 2 01-24-2013 08:06 AM
removal of load bearing wall Carlos 45 Building & Construction 4 01-31-2012 06:25 PM
Removing bearing wall and putting up a beam Sardinia Building & Construction 2 02-21-2011 06:11 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
