To Visqueen Or Not To Visqueen? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Gary in WA
Old 07-20-2016, 12:24 PM   #1
Rewards Points: 18
To visqueen or not to visqueen?
I have removed a 6'x8' dbl. french door from a patio to a bedroom. I framed the opening and insulated with craftfaced R19 and dry-walled the inside. I put up durarock on the outside. I'm installing vertical 6" T&G bead board as an accent wall to cover the outside. It will be stained and sealed with a spar varnish. The question is should I put up visqueen over the durarock to add a moisture barrier under the T&G, or is it not necessary and will it not allow the wood to breath. The porch is covered and screened, only possibility of rain is during a hard storm. We are very humid here in Florida, so...?
Any input is appreciated.
RMDman is offline   Reply With Quote
Old 07-26-2016, 12:38 AM   #2
Registered User
Rewards Points: 526
Re: To visqueen or not to visqueen?
------------Welcome to the forums!-----------------No visqueen, just housewrap or better yet, builders paper for your WRB; http://buildingscience.com/documents...uth-assemblies
http://buildingscience.com/documents...gs?full_view=1
Gary
BigJim likes this.
Visqueen Over Newly Layed Outdoor Tile???? Ralph III Flooring 1 12-03-2012 06:24 PM
