Vinyl Siding Over Metal Siding - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 06:05 AM   #1
vinyl siding over metal siding
is it ok to put vinyl siding over metal siding, would it cause mold or mildew?
Kvjordan is offline   Reply With Quote
Old 05-28-2013, 06:25 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,312
Should be fine.
Begs the question as to why you would want to when tear off is pretty easy and will give you the ability to improve the sheathing air tightness and flashing details around windows.
Rigid foam is also a great upgrade when it comes to siding your home.
Old 05-28-2013, 06:48 AM   #3
When you say "metal"?
Do you mean steel - aluminum...?
rossfingal is offline   Reply With Quote
Old 05-28-2013, 07:27 AM   #4
Rewards Points: 3,130
If it's aluminum, I'd pull it off. That stuff can be recycled for quite a bit of money. Steel, not so much. But I'd pull that off too.
Old 05-28-2013, 08:29 AM   #5
Rewards Points: 17,890
No way would I go over it.
How would you even trim around the windows and doors and not have it leak around the old metal J moulding.
You want the trim to stick out past the siding, all the windows and doors would have to be built out if you left the old on.
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 09:02 PM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-13-2009 11:16 PM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
