Vinyl Plank Flooring - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-10-2014, 05:15 PM   #1
Rewards Points: 4
vinyl plank flooring
Has anyone had any experience laying vinyl plank flooring over 12 x 12 ceramic floor tile. Will the grout lines eventually show thru?
marv1 is offline   Reply With Quote
Old 11-10-2014, 05:32 PM   #2
Rewards Points: 17,890
There has to be at least 1000 old post on this subject.
Tried the search option yet under flooring?
Yes all the grout lines are going to show through.
What's wrong with the old tile?
How's adding another layer of flooring without removing the old flooring going to effect meeting up with the other floors?
Old 11-10-2014, 05:46 PM   #3
Rewards Points: 4
I was just being lazy and not wanting to remove the old ceramic tile
Old 11-10-2014, 05:58 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You do not want to do that. At the very least the ceramic tile must be scuffed and the grout lines filled. Otherwise the joints in the vinyl plank flooring will quickly separate and the floor will wreck itself. And even then if the floor isn't plane the vinyl will still fail.
XXX
Vinyl plank is cupping-seller says put down plastic akimbo Flooring 3 02-04-2012 10:37 PM
Laminant vs vinyl plank flooring gin and ger Flooring 2 01-27-2012 11:31 AM
Asbestos Vinyl Sheet Flooring Backing Codyy Safety 3 01-04-2012 11:09 PM
vinyl plank flooring dspottenger Flooring 4 07-29-2011 10:35 PM
? vinyl plank flooring markhelton Flooring 1 12-13-2010 10:35 PM
