Vertical Hole Drilled Through A Horizontal Support Beam - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By SPS-1
  • 1 Post By Tom738
  • 1 Post By MI-Roger
Old 11-23-2017, 12:16 PM   #1
Rewards Points: 4
Vertical Hole Drilled Through a Horizontal Support Beam
We discovered a vertical hole drilled through a horizontal ceiling beam going across our 18 foot wide room. We live in a second floor condo with one condo above and below us. There are ceiling heater power cords running through the hole which have the control knob at the end. The control knob was embedded in a wall we removed.
We asked the condo manager to bring a structural engineer to examine it and she said we had to get our own and pay for it ourselves.
Is the vertical hole a possible structural problem?
Should we get a structural engineer to examine it?
The condo manager said she doesn’t have a blueprint for our condo, only an 8 1/2 x 11 inch drawing. Where can we get blueprints? The architect has passed away. The condo manager said we would also have to pay an architect to create blueprints for the existing space. She said she thought the structural engineer would want them.
Any thoughts and suggestions are welcome! Thanks!
Vertical Hole Drilled Through a Horizontal Support Beam-36965d2c-99ec-4b53-99af-9b5121cfecb5.jpg
Newbiediyer13 is offline   Reply With Quote
Old 11-23-2017, 01:21 PM   #2
Rewards Points: 898
Re: Vertical Hole Drilled Through a Horizontal Support Beam
Leave it.
BIG Johnson is offline   Reply With Quote
The Following User Says Thank You to BIG Johnson For This Useful Post:
jlhaslip (11-23-2017)
Old 11-23-2017, 01:23 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,628
Step back a little and provide a picture of the joist with its related supporting members, such as posts, walls, etc. Is this a vertical hole or an angular hole?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 11-23-2017, 01:34 PM   #4
retired framer
Rewards Points: 18,670
It was passed at time of construction, so as long as you are not drilling more holes it will be fine.
Old 11-23-2017, 05:47 PM   #5
Rewards Points: 4
[QUOTE=chandler48;4855842]Step back a little and provide a picture of the joist with its related supporting members, such as posts, walls, etc. Is this a vertical hole or an angular hole?
Okay, I took some more photos.
Vertical Hole Drilled Through a Horizontal Support Beam-4bbba04f-acad-45a5-b756-41d78870775a.jpg
Vertical Hole Drilled Through a Horizontal Support Beam-357fc6b3-0c61-44a4-a1b9-39a662d79f5a.jpg
Vertical Hole Drilled Through a Horizontal Support Beam-5e9c0897-81ab-4d62-a4b2-226225c9cd1a.jpg
Vertical Hole Drilled Through a Horizontal Support Beam-3131fbf9-f165-4609-9215-228ff5c9ff87.jpg
Old 11-23-2017, 06:22 PM   #6
Rewards Points: 7,202
Keep stepping back. The new photos are just as up close as the original. Chandler is asking to see where the beam is supported.
chandler48 likes this.
SPS-1 is online now   Reply With Quote
Old 11-24-2017, 07:39 PM   #7
Rewards Points: 1,222
It's most likely been this way for a long time and there are no issues with the beam. It is fine and it is nothing to worry about and certainly doesn't warrant bringing out engineers unless you are in a big hurry to part with your money. The only thing that I can't understand from your pictures is how the drywall sat over the wires, must've been shimmed out I assume. It appears from the last pic that you have a vertical beam within about 16 inches of the hole, if this is the case that alone should give you peace of mind. As others have said, back up a little and get a picture with a better overall view.
CrazyGuy is offline   Reply With Quote
Old 12-10-2017, 05:02 PM   #8
Rewards Points: 1,410
Don't just take the condo manager's word for it. Look at your actual condominium documents. Structural elements are often considered common elements and the responsibility of your Condo Association.
Fix'n it likes this.
Tom738 is offline   Reply With Quote
Old 12-18-2017, 07:35 PM   #9
Licensed Engineer
Rewards Points: 467
What is up and what is down in the photos? If the hole was drilled in the dead-center of the beam it would be of no consequence being on the 'neutral axis'. Having the hole in the upper side is less of a problem than the lower side since the top side of a horizontal beam is in compression and the lower side in tension. Wood is much stronger in compression than tension.
Will the wires remain after the renovation?
Oops! I just realized you said it was a vertical hole. That changes my answer, but I still can't tell what is up and what is down in these photos.
Nealtw likes this.
MI-Roger is offline   Reply With Quote
Tags
#verticalholeinbeam
Engineer didn't include support beam, now need one Jobe2 Building & Construction 15 05-17-2017 05:55 AM
install vertical support beam for porch Creality4U Building & Construction 5 08-02-2015 09:09 AM
new member with question on support beam pointer80 Building & Construction 7 02-02-2012 09:23 PM
Main structural support beam HELP!!! Daniel048225 Building & Construction 34 02-16-2011 11:35 PM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 10:51 PM
