Using Different Style/size Crown? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-21-2015, 12:58 PM   #1
Rewards Points: 636
using different style/size crown?
I'm looking to install crown moldings in our house. The way the house was design we have 3 different height ceilings downstairs.
The livingroom and the dining can be view from any angle of the area. The living room has a vaulted ceiling with 18ft down to 9ft the dinning room area is only 8ft.
The Family room is separated and have a 10ft ceiling.
I want to install 7" crowns in the family room and the living room. Debating on if I should crown the dining room and if I do, the 7" crowns would be an overkill. I want to stick with a 5" crown for that area but the style has to be different since they don't have the same style crown in the 5 of the 7" that I already purchased.
None of the ceiling lines of the crowns will be joint as they're all separated so I don't have to worry about the different size. Not sure if it would look right/uniform.
dannieboiz is offline   Reply With Quote
Old 07-21-2015, 01:14 PM   #2
Rewards Points: 474
I guess photos would help a lot...
BrowneBearLLC is offline   Reply With Quote
Old 07-21-2015, 01:31 PM   #3
Rewards Points: 636
the left is the living room with the vaulted ceiling the right actually has a 6 or 8" step to the dining room.
Proper chimney crown -- need advice Rav Concrete, Stone & Masonry 7 08-03-2014 11:14 AM
Ceiling Crown Gaps: Eliminate Via Screws? Twister Carpentry 24 08-19-2013 07:46 AM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 10:52 PM
Mixing differnet crown moldings moondog111 Carpentry 13 12-07-2008 09:40 PM
