Use Double Joist Hanger When One Joist Splits A Little? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By Guap0_
  • 2 Post By Nealtw
  • 1 Post By Nealtw
  • 1 Post By petermole
  • 1 Post By Nealtw
Old 08-08-2018, 08:03 AM   #1
Rewards Points: 104
Use double joist hanger when one joist splits a little?
Hey, me again! I'm about done with replacing my load bearing wall with LVLs. (2x8 joists are going into 3 ply 16" LVL using LUS28 joist hangers. One of the joists has a sort of split off corner. Not too bad. I have some 2x8 scrap around. I could just screw a short piece to the end of the joist and then use a double joist hanger. Would that be a good fix?
petermole is offline   Reply With Quote
Old 08-08-2018, 08:52 AM   #2
Guapo
Rewards Points: 11,950
Re: Use double joist hanger when one joist splits a little?
Flip the joist so the chipped corner is on top.
de-nagorg likes this.
Guap0_ is offline   Reply With Quote
Old 08-08-2018, 10:30 AM   #3
Rewards Points: 104
Sorry, I should have explained better. I took down a load bearing wall and am now installing a LVL header. The joists are already in place and have been cut to accept the header being placed up into the ceiling. Joists intersect with header at 90 degree angles.
Old 08-08-2018, 12:14 PM   #4
JUSTA MEMBER
Rewards Points: 3,672
Then your plan of adding a double patch, sounds logical.
I might go for even tripling it, one short patch piece on both sides of the existing joist, if you have room to install it.
Add some plate steel on both sides of the patch, and through bolt it in a sandwich.
This should then be inspected by an engineer to see if it still passes code, but I believe that it will.
ED
de-nagorg is offline   Reply With Quote
Old 08-08-2018, 02:14 PM   #5
retired framer
Rewards Points: 18,874
Adding 2 feet beside a damaged joist is done all the time.
MTN REMODEL LLC and de-nagorg like this.
Old 08-08-2018, 06:13 PM   #6
Rewards Points: 104
Okay guys, thanks for the help.
Old 08-08-2018, 06:18 PM   #7
retired framer
Not sure what the nail pattern would be on a scab like that, with a nail gun in hand we just nailed the crap out if it. And no one ever called us on it.
MTN REMODEL LLC likes this.
Old 08-09-2018, 09:27 AM   #8
Rewards Points: 104
For bringing the 3 LVL plys together, the structural engineer has me using these FastenMaster screws, either 5" TrussLok or TimberLok. 2 rows of screws every 2', then same on the other side staggered. They don't need a pilot hole and come in flattop style so you can drywall over them.
My only comment about nailing the crap out of it is that you should probably stay away from the top and bottom 2" of the header or joist.
Old 08-09-2018, 09:34 AM   #9
retired framer
We don't get to use screws for anything yet except on decks
But the engineers call for the beam and whatever they want is what they get unless he gave you a choice. If you don't like or can't do what he suggested call him, he has choices to work with.
Old 08-15-2018, 08:45 AM   #10
Rewards Points: 104
Just want you guys to know this project worked out fine. Thanks for your help.
What's the best way to remove nails from joist hanger? johnv713 General DIY Discussions 26 10-03-2014 09:39 PM
Last Joist Hanger on overhang gkaro Building & Construction 6 04-04-2012 11:56 PM
Joist Hanger Question? mopowers Carpentry 11 08-22-2010 01:56 AM
Double Ceiling Joist Rking Building & Construction 9 05-16-2010 11:50 AM
Double Rim Joist Clutchcargo Building & Construction 2 06-19-2009 08:12 PM
