Uneven Tile Spacing Problem - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By rjniles
Old 07-18-2018, 11:03 AM   #1
Rewards Points: 2
Question
Uneven tile spacing problem
Hi, I'm on the tail end of my kitchen remodel. Granite countertops were installed yesterday. I plan to lay 3x6 subway tile for a backsplash. I noticed after the countertops were installed that there is an uneven small space between the window trim and countertop backsplash. It's an old house and nothing was square or level. I'm afraid it's too small to tile and given that the width varies from 1 inch to 2 inch across the length of the window, it's extremely noticeable now with the new countertops. How do I hide this uneven space? I'm considering several things including permanently removing the bottom window trim and tiling, maybe not tiling that space at all and painting it in a color that minimizes the variance. Can I trim the bottom window sash to correct it by creating an optical illusion? I don't know what to do with it. I've uploaded a photo to better illustrate the problem. Thank you for any advice or suggestions!
DIYBonnie is offline   Reply With Quote
Old 07-18-2018, 11:27 AM   #2
Rewards Points: 7,168
Re: Uneven tile spacing problem
I would either:
a) do nothing. Nobody will notice the bottom of the window molding is not parallel to the countertop (except you, who will notice every time you go into the kitchen)
b) trim the bottom of the window molding do that it is parallel, or close to parallel, with the countertop.
SPS-1 is offline   Reply With Quote
Old 07-18-2018, 11:45 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 592
Remove the window apron and tile up the bottom of the hill.
Sent from my Moto E (4) Plus using Tapatalk
SPS-1, 123pugsy and HDS like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 07-18-2018, 11:48 AM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,264
X2. The bigger space full of tiles should hide it more.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 07-18-2018, 04:50 PM   #5
Rewards Points: 4,134
Just my opinion.
I would remove the trim and run the tile level
Half the distance will be revealed on each side
Making it less obvious.
ron45 is offline   Reply With Quote
Old 07-19-2018, 12:42 PM   #6
Rewards Points: 64
Originally Posted by SPS-1 View Post
I would either:
Isnít that what the guy who built the Leaning Tower of Pisa said?
Itrim is offline   Reply With Quote
Old 07-19-2018, 03:32 PM   #7
Two Knots's Avatar
Rewards Points: 3,875
Bonnie, is the window level? Did you put a level on the sill?
My first thought is to remove the sill and trim underneath the sill
and raise up the sill and bottom window trim up -- until it's level
from the front...one subway tile along the top of the counter ( under
the sill ) would then look level. It would cover the bottom trim on the
window just showing the window glass.
That's my first thought...I do have one other.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is offline   Reply With Quote
problem with a simple floor tile design wengang1 Flooring 8 03-24-2013 02:23 PM
tile floor problem wengang1 Tiling, ceramics, marble 8 03-22-2013 06:12 PM
Uneven tile...HELP!! ptview Flooring 10 04-19-2011 08:39 PM
Floating floors over uneven Ceramic Tile jaiken49 Flooring 1 10-14-2010 05:57 AM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 06:22 PM
