Underground Plumbing On Basement Floor Is Not According To Layout - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By MTN REMODEL LLC
  • 1 Post By TarheelTerp
Old 02-20-2018, 08:39 AM   #1
Rewards Points: 4
Underground plumbing on basement floor is not according to layout
Hello Everyone,
My house is one year old and is located in Ontario, Canada.
The basement rough-in plumbing was finished when the house was built. I am now starting to finish the basement and I found out that the plumbing in the bathroom is off by about 12". I have been able to solve most of the issues by changing the layout but the area where the shower needs to be, has the plumbing way off and I cannot move the shower to make it fit (please see attached picture)
I am not too keen on breaking the concrete floor to relocate, so I though that I could build a 4 " concrete or wooden riser, that would be about the size of the shower (32" x 60"), that will basically hid the rerouting of the plumbing that I will do above the concrete floor
Any advise?
Jcornejo
Underground plumbing on basement floor is not according to layout-img_2898.jpg
Jcornejo is offline   Reply With Quote
Old 02-20-2018, 08:51 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
Re: Underground plumbing on basement floor is not according to layout
I have not figured out if it would be even possible to proprly drain and vent that shower with your 4" riser.
BUT: I think you would be asking for a difficult mess trying to do that. First you'd be getting a very strange functionally difficult shower,,, probable all sorts of modifications around the shower.... just a boat load of headaches.
Busting up that concrete is not that difficult and probably your easiest approch in my opinion.
Marson likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 02-20-2018, 08:54 AM   #3
Peace be with you
DR P's Avatar
Rewards Points: 1,860
we would need triangulated measurements of all drain stubs
including toilet flange to better determine your layout...
distances off walls & also measurements between pipes
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
Jcornejo (02-20-2018)
Old 02-20-2018, 09:45 AM   #4
Rewards Points: 4
Thank you for your reply. Whether it is 4" or 6" wouldn't be an issue as I would do the height required to have proper drainage.
If I break the concrete to fix the plumbing, what are the chances that I can have issues with underground water leaking into the basement (between the old and new concrete)?
Old 02-20-2018, 09:50 AM   #5
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,122
Originally Posted by Jcornejo View Post
I am not too keen on breaking the concrete floor to relocate...
Get over it. Then you can be sure you'll get the venting & traps right
as well as placing the shower drain *exactly* where you want it.
Also... allow more thickness on the exterior wall for the 2" XRP behind the framing.
MTN REMODEL LLC likes this.
Old 02-20-2018, 09:51 AM   #6
What's the chance you have sub surface water issues....???
Yes a cold joint in your basement will likely have a greater permeability than a good slab..... but slabs crack all the time, with no water problem, unless you have an underlying subsurface water issue with your foundation.
Old 02-20-2018, 11:46 AM   #7
retired framer
Rewards Points: 18,386
Usually they miss by 8, he added 4" for the wall and then screwed up.
I would break into the concrete and do it right. The tub drain may have foam just under a bit of concrete around it. If you find water down there, that's a warrantee issue.
Tags
basement bathroom , basement drain , basement floor , plumbing
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement Plumbing Rough-In... elliot Plumbing 0 09-17-2011 02:46 PM
Plumbing leak in basement - HELP jamieblosser Plumbing 2 06-16-2011 11:44 AM
Basement Bathroom Rough-In Layout robinma Plumbing 1 12-03-2008 10:25 PM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 08:30 AM
