Undercounter Trashcan - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Guap0_
Old 03-26-2018, 09:15 PM   #1
Rewards Points: 72
So, bit of a weird question here, and not even sure this is the correct place for the post.
I recently installed a Rev-A-Shelf under counter trash can (see attached pictures). Works great. It replaced a foot-pedal trash can that was in the way as we were walking through the kitchen. The only drawback is that we have to manually lift the lid. I was wondering if anyone had any ideas/experiences on how to make this lid open automatically when I pull it from under the counter and close again when slid back in?
I contacted the manufacturer to see if they made a battery/sensor operated lid, but they don't. I was thinking some sort of spring might work but I do anticipate a few problems with a spring.
Anyhow, this community has never let me down, hoping they have some experiences or ideas to share on this one.
welshie is offline   Reply With Quote
Old 03-26-2018, 09:17 PM   #2
Rewards Points: 72
Re: Undercounter Trashcan (with pictures)
Here are the pictures
Old 03-26-2018, 09:31 PM   #3
Guapo
Rewards Points: 11,950
Any of the under the counter trash cans that I have seen didn't have a lid. Would you be okay with that?
ron45 likes this.
Guap0_ is offline   Reply With Quote
Old 03-26-2018, 09:39 PM   #4
Rewards Points: 72
Hi Guap0,
Definitely want the lid on there. It's the trashcan for landfill which means food leftovers etc etc going in there. Too stinky not to have a lid. And can't swap it for the recycle trashcan as the designated recycle trash can is (and needs to be) significantly bigger than this under-the-counter one.
BTW, the gap between the top of the lid and the underside of the counter is approx 1 & 3/8". But I can move the trashcan higher or lower for a good solution (if one exists).
Old 03-26-2018, 09:56 PM   #5
Guapo
So far, the closest that I've found is what they call a "click top" where you press a button & the top opens.
http://sterilite.com/mobile.html?id=...=210&section=3
Old 03-26-2018, 10:18 PM   #6
retired framer
Rewards Points: 18,838
Steel the foot pedal mechanism and rig it to the new one and figure a way that it activates when the draw is pulled out.
Old 03-27-2018, 04:39 AM   #7
Naildriver
chandler48's Avatar
Rewards Points: 3,686
Not sure if it would fit, but you may contact the manufacturer to see if there are other sizes. https://www.homedepot.com/p/iTouchle...ZT13/100653815
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Undercounter Water Filtration System cprao Remodeling 1 06-19-2018 07:25 AM
Undercounter Potlights - Any Recommendations? RCGA Electrical 9 10-28-2013 12:46 PM
undercounter lighting timchi29 Electrical 2 01-01-2011 01:35 PM
undercounter sink bickey Tiling, ceramics, marble 2 05-25-2009 01:30 AM
Mount an undercounter sink on top? nicksteel Plumbing 3 08-31-2008 07:18 PM
