Tub Mortar Bed Confusion - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-17-2017, 08:22 PM   #1
We've gutted our bathroom and we are ready to install our new tub. We purchased an American Standard Ovation bath tub. Upon unboxing it has a particle board 'base' attached to it. We have a couple questions to ensure that we install it properly.
1. The tub is on the ground floor and will be installed on a concrete slab- do we need a mortar bed?
2. Also, if we use a mortar bed- how long does it have to cure before we can stand in the tub? I will be installing tile on the walls once the tub is in.
Thank you in advance for helping!
Jennie1019 is offline   Reply With Quote
Old 07-18-2017, 01:43 AM   #2
Professional
Rewards Points: 188
Re: Tub Mortar Bed Confusion
Hi, Many tubs no longer require a mortar bed. I tend to stick with manufacturers installation methods to keep in warranty. Read instructions twice, proceed! Good luck with your project.
Str8AheadInc is offline   Reply With Quote
Old 07-18-2017, 05:30 AM   #3
Rewards Points: 898
http://www.homedepot.com/catalog/pdf...a156afbc6e.pdf
"4. It is recommended that the tub be set in a small bed of mortar or grout tocompensate for uneven floors. Stringers will help level tub but will not provide adequate support."
1 day should be good.
BIG Johnson is offline   Reply With Quote
brick mortar not quite "sticky" enough shaftmaster Concrete, Stone & Masonry 7 04-02-2015 04:54 PM
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 10:41 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 07:52 AM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 07:44 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 11:13 AM
