Tongue And Groove Kitchen - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By ZZZZZ
  • 1 Post By MTN REMODEL LLC
  • 1 Post By ryansdiydad
Old 03-26-2017, 10:15 AM   #1
Tongue and groove kitchen
Okay so basically my entire house is tongue and groove wood. I don't mind it for the most part but I feel like it could use something different to break up the tone. We just put up new cabinets in the kitchen, but I feel like it needs something else to brighten it up or something. I was thinking about a backsplash or something, but I'm wondering if we should just paint the whole room, or replace with sheetrock and then paint? Any ideas or suggestions welcome
missmickella is offline   Reply With Quote
Old 03-26-2017, 10:33 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,050
Re: Tongue and groove kitchen
I'm assuming you mean that your walls are T&G.
We have no idea of your budget or tastes.
But, I note that paint is cheap and probably the easiest way to quickly change decor.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-26-2017, 10:39 AM   #3
Don't really have a set budget, but yes the walls in the entire house are tongue and groove. Here's a picture of the kitchen, pardon the mess
Old 03-26-2017, 10:43 AM   #4
ZZZZZ's Avatar
Rewards Points: 2,158
I might just do a whitewash of the ceiling T&G to brighten it up a bit. It's cheap and quick, and if you don't like it, go ahead and paint it full white.
MTN REMODEL LLC and Dave Sal like this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is offline   Reply With Quote
Old 03-26-2017, 10:47 AM   #5
CAUTION..... I'm no decorator... and don't even pretend to know anything.
But, personally, I agree with you and think it may be that you have a monotone to everything.... and maybe some contrast (paint) will dramatically change things.
I really wish we had some pro decorators on here.... how could we solicit them.
Best
ZZZZZ likes this.
Old 03-26-2017, 12:13 PM   #6
Rewards Points: 1,514
You have the right idea.. I'd consider painting the T&G on the sides and do a backsplash... some people have a stroke if you suggest painting over wood like that but sometimes you just need to do it...
Another idea, which may make no sense in your situation, would be to drywall over the T&G in that area... that will really make it a defined space vs the rest of the house...
MTN REMODEL LLC likes this.
ryansdiydad is offline   Reply With Quote
Old 03-26-2017, 02:49 PM   #7
I asked my boyfriend about painting any he doesn't seem to like the idea and doesn't think it will look good. I'm thinking we may try it and if it looks horrible just do drywall instead. Just hard to envision what it's going to look like
Old 03-26-2017, 03:40 PM   #8
in your case drywall on that left side wall would most likely require you to remove the T&G and maybe even those upper cabinets at least to have it look even remotely good.. as you said start with paint.. then live with it for a while and see how it works out...
Painted T&G looks like in these pics.. at least that's how they look on my ceilings
ZZZZZ likes this.
Old 04-02-2017, 07:14 PM   #9
Professional
Rewards Points: 188
I would rip out the wall t n g and install drywall for the best results. This would require removing cabinets as well but would be worth it.
Str8AheadInc is offline   Reply With Quote
Is drywall required under tongue & groove ceiling? ZZZZZ Building & Construction 9 12-25-2015 11:05 AM
Remove tongue and groove or... Westond Flooring 7 09-30-2013 01:05 PM
How to repair tongue and groove that is subfloor cosmicblu Flooring 1 08-19-2011 05:12 PM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 10:40 AM
Install Cabinets directly above Tongue & Groove? caezaar Building & Construction 13 07-06-2010 09:50 PM
