Toilet In Garage W 3 Inch Drain - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-06-2014, 10:48 PM   #1
toilet in garage w 3 inch drain
i have a 390 square foot garage that I want to make into a studio apartment.
In one corner there is are two water spigots - hot and cold water. In the center of the garage is a drain that looks like 3 inches around. It goes down about 15 inches and turns at 90 degree angle. I flushed water from the hose into it for 5 minutes, and it continuously drained.
I'd like to add a bathroom with toilet, shower, and sink. I'd like to add a kitchenette, and a drain for a small clothes washer.
Would I be able to use the drain for the toilet? In general, how would I connect the toilet, sinks, and showers to the drain? Would I run pipes on the ground and then build a subfloor? Are two spigots enough for all the water needs of the studio?
Finally, in general, what kinds of costs am I looking at? I'm thinking I won't need to tear up the floor, is that correct?
Thanks!
mike1977 is offline   Reply With Quote
Old 09-06-2014, 10:56 PM   #2
JUSTA MEMBER
Rewards Points: 3,576
I may be mistaken and if so someone will be along soon to correct me.
I thought that garage drains were required to be hooked up to the storm sewer system. and if so they do not want sanitation sewer water in the storm sewer.
I say no. You should tie into the sanitation line for the home instead.
ED
de-nagorg is online now   Reply With Quote
Old 09-06-2014, 11:03 PM   #3
Too bad, but it did seem too easy to be true. So I would have to run the sanitation pipes through the garage wall into my basement to tie into the sanitation line, right? It's quite a distance away, but I guess that's how to do it.
Aside from that, are there any other major plumbing issues to be aware of?
Thanks.
Old 09-08-2014, 06:37 AM   #4
Rewards Points: 3,130
Your profile doesn't say wher you live. Have you checked to see if you can legally do what you're planning in your neighborhood? I know my in-laws had a heck of a time getting approval to create an apartment in their home for one of their aging parents. Could be a bigger problem if the plan is to rent the unit out.
Tags
draim , garage , toilet
Toilet Only on Drain Line Perry401 Plumbing 1 09-27-2011 01:30 PM
Drain line for toilet PatSea Plumbing 6 06-11-2011 10:53 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
