Tiling Over Painted Sheetrock - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By 195795
  • 1 Post By 195795
Old 12-29-2018, 06:41 PM   #1
Rewards Points: 2
Tiling over painted sheetrock
Our DIY basement remodel is partially complete - except that I realized after-the-fact that drywall in the shower will be problematic and I already painted. We used a one-piece fiberglass tub/shower and there’s about 24 inches of painted Sheetrock between the top of the tub and the ceiling. The shower faucet is about 10” from the ceiling. It’s purple drywall that the drywall guys said is for use in bathrooms but I believe it’s going to get saturated.
I would like to somehow waterproof it and tile over it with white subway tiles. My husband says we cannot use Kerdi waterproof membrane because the drywall is painted and unmodified thinset will not adhere.
I think there has to be a way to make this area waterproof, I just don’t know what to do.
Any suggestions will be appreciated!
jennjones is offline   Reply With Quote
Old 12-29-2018, 08:52 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,594
Re: Tiling over painted sheetrock
You can't make sheetrock waterproof. However, if this is above the shower, it may not pose as much a problem as you think. It ideally should be concrete backer unerlayment or Kerdi (it will adhere just fine with thinset). Purple drywall is fine for bathrooms, but not for wet areas. Technically your area won't be a "wet" area, even though it may get splashed occasionally.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 12-29-2018, 09:02 PM   #3
Rewards Points: 1,272
RedGard it and go
chandler48 likes this.
195795 is offline   Reply With Quote
Old 12-30-2018, 06:38 AM   #4
retired painter
Rewards Points: 1,326
Tile gets installed over paint everyday although if the paint has a sheen it should be scuff sanded first. A good coat of latex enamel along with caulking between the drywall and tub surround should give you all the protection you need. Not trying to talk you out of tile - just saying it isn't necessarily needed.
mark sr is online now   Reply With Quote
Old 12-30-2018, 09:48 AM   #5
Rewards Points: 20
I agree with Texasdiyer, use RedGuard (found at Home Depot, Ace Hardware, Walmart, etc.) which creates a waterproof membrane then paint that and you should be fine.
TheNexus is offline   Reply With Quote
Old 12-30-2018, 10:06 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
Never heard of that one...??????
MTN REMODEL LLC is offline   Reply With Quote
Old 12-30-2018, 10:56 AM   #7
Rewards Points: 1,344
Redguard is not meant to be painted and used as a “wear” surface. It is a sub-strate membrane meant to get tile over it.
ront02769 is offline   Reply With Quote
Old 12-30-2018, 01:06 PM   #8
Funny - I meant RedGard and then tile over it since that's what Jenn was asking about.
However, I have also painted over it as well with no issues.
I didn't want tile around my soaking tub so I hit the drywall with a couple coats of RedGard, sprayed on knockdown texture and then painted it. Likewise with drywall above shower tile up to ceiling - no issues.
Tiling over painted concrete - bond promoting primer? tbick Tiling, ceramics, marble 2 01-18-2018 08:21 AM
Question on applying new sheetrock on walls Atlas227 Drywall & Plaster 19 08-12-2016 10:16 PM
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
Tiling over painted cement, but can't remove paint... what to do? arronsky Flooring 9 06-29-2013 04:36 AM
Tear down old fireplace or sheetrock over? hootsmcgoots Remodeling 4 04-30-2012 09:08 PM
