Thinset Tile Installation - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-24-2017, 10:49 AM   #1
Rewards Points: 4
Thinset tile installation
I will be setting 3/8 mosaic tile shower floor with thinset over a mudbed. how much additional depth do i need around my drain in addition the the 3/8 for the tiles?
ljones1949 is offline   Reply With Quote
Old 04-24-2017, 09:58 PM   #2
Rewards Points: 1,002
Re: Thinset tile installation
An eighth should do it. To be sure, mix up some thinset and lay a tile on a sidewalk or something and measure it, then pull it off and clean it up. It will come down to micrometers. If you want to be exact, get a pile of index cards or some sort of paper and measure the height that way.
Then you'll have to make sure you trowel everything the exact same way and set the tile with the exact same force.
Let us know what you come up with.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
ljones1949 (04-25-2017)
Old 04-24-2017, 11:08 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
Put some clean/small gravel by your drain weep holes.....
Generally, I design/set my drain weep holes at the base of my preslope/membrane...then it doesn;t matter alot as long as I'm not puddling at the drain.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Tags
morter depth , shower , thinset
tile adhesive or thinset? Leoskee Tiling, ceramics, marble 4 11-28-2016 02:09 PM
Tile lippage-acceptable or not? KC33 Tiling, ceramics, marble 10 12-04-2015 02:33 AM
Tile backsplash installation questions mudworm Building & Construction 11 12-11-2014 04:51 PM
Does a concrete slab floor need to be level prior to tile installation? Malcolm Flooring 9 06-03-2014 09:39 PM
Floor Installation - Porcelain Tile over VCT...Please help diyuser1999 Flooring 3 05-20-2012 07:48 PM
