Is There A Way To Repair/replace A Rotted Window Sash? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-09-2019, 10:52 AM   #1
Rewards Points: 26
Is there a way to repair/replace a rotted window sash?
2 back windows are rotted at the bottom. Is there a way to fix these? Can I take them somewhere to have them fixed like a carpenter? I saw a video on youtube where the guy built a new sash but I'd rather not do it myself especially that this is a double pane window. Wondering who to hire for this as window repair companies usually just repair the glass and seals, not the wood.
parmesan is offline   Reply With Quote
Old 05-09-2019, 11:01 AM   #2
Rewards Points: 222
Re: Is there a way to repair/replace a rotted window sash?
I am not sure I would even attempt to repair that--looks like you need a new window in my opinion.
jsmith1107 is offline   Reply With Quote
Old 05-09-2019, 11:28 AM   #3
retired painter
Rewards Points: 1,352
It can be repaired. The bottom would need to be removed and a board cut to match what came off [including rabbit or dado] Finding someone to do the job will be a lot harder than finding someone to replace the window.
mark sr is offline   Reply With Quote
Old 05-09-2019, 02:16 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
Yep. As Mark Sr. said. What is the breadth of your carpentry skills?
Old 05-09-2019, 02:48 PM   #5
Rewards Points: 26
Not too good but I guess I'll give it a try.
Old 05-09-2019, 02:56 PM   #6
retired framer
Rewards Points: 18,500
There are companies that make replacement sash, if the rest of the wood is sound.
https://www.marvin.com/marvin/window...-hung-tilt-pac
Do not use flat bottom gables with scissor trusses.
Old 05-09-2019, 03:15 PM   #7
Rewards Points: 6,887
Some knot free wood, a table saw and a bit of thinking should get the job done. A planner or good sander will help.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
How to remove sash from Aluminum window frame? Johnnyb69 Windows and Doors 2 02-04-2019 12:13 PM
The great window debate michiganman13 Windows and Doors 0 08-20-2017 05:36 PM
Removing old wooden upper window sash for reglazing lienco0915 Windows and Doors 8 08-15-2017 09:36 PM
How to disassemble aluminum clad wood window sash? JohnBinSC General DIY Discussions 6 01-17-2011 05:59 AM
drilling sash on vinyl window rtoni Building & Construction 1 08-05-2008 03:55 PM
