Taping Transition From CB To Drywall - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-21-2017, 07:16 AM   #1
Rewards Points: 66
taping transition from CB to drywall
How should i tape the transition from CB to DW? should i use quickset or joint compound? thanks
owenpga is offline   Reply With Quote
Old 02-21-2017, 03:51 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: taping transition from CB to drywall
Are you saying the tile ends right on the joint, or does the tile go onto the DW a bit?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-24-2017, 08:33 AM   #3
Rewards Points: 2,464
I usually tile to the ceiling around the tub or shower, and use thinset then redguard over the horizontal seams. Vertical seams I use compound, redguard to the edge of tile. If tub is 30" wide, I usually tile 36" then drop down to about 5' high for 8' ceiling bathroom. The vertical joint is usually not where you get water damage. Compound is only finish material that you can sand to smooth paint finish.
carpdad is offline   Reply With Quote
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 08:42 AM
drywall taping ohliuw Drywall & Plaster 11 07-29-2014 03:58 PM
Taping drywall behind cabinets? benjamincall Kitchen & Bath Remodeling 6 06-08-2010 05:40 PM
Durock (CBU) to Drywall transition HELP Honeydo_MD Drywall & Plaster 5 03-28-2010 09:50 AM
Durock (CBU) to Drywall Transition HELP Honeydo_MD Drywall & Plaster 1 09-16-2009 11:24 AM
