T&G Window And Door Trim - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-16-2019, 04:51 PM   #1
Solutions (handyman)
Rewards Points: 462
T&G window and door trim
Which is the preferred way, attaching the pine trim around the windows and doors, then butting the pine T&G boards to the trim or boards first with the trim on top of the boards.
Mark Harvey is offline   Reply With Quote
Old 01-16-2019, 06:03 PM   #2
Rewards Points: 17,896
Re: T&G window and door trim
I can not think of any reason inside or out to install any trim before the T & G is done.
Need far more info on what exactly what is is you doing.
Old 01-16-2019, 06:30 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,692
Are you installing the T&G over sheetrock or over studs? I've done it both ways, and with studs, you will need a 1/4" shim extension to bring it all out flush. With the sheetrock, you'll need 3/4" jamb extensions.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-16-2019, 06:49 PM   #4
retired framer
Rewards Points: 18,872
Stop short of the jam and deal with the trim with extensions.
Old 01-16-2019, 08:10 PM   #5
Rewards Points: 462
The build is under an existing deck where we are filling in the open space. All walls are studs. The same question applies to the windows. And no, there is no
drywall just studs. Just want it to look finished.
Old 01-16-2019, 08:20 PM   #6
retired framer
Outside is different. You do put trim on first and but into it but the trim will have to be less that 3" or you will have nothing to nail too.
Or you could rabbit out the back corner of the trim so the boards go behind a 1/2" If you have water thru the deck you should have flashing above a window or door.
https://www.protradecraft.com/pro-pi...al-trim-boards
