Sunroom Exposed To Ellements - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-09-2017, 11:07 AM   #1
Rewards Points: 78
Sunroom Exposed to Ellements
Hi all,
I have a sun room off the back of my house that is considered a 3 season room. It is screened in only so it is open to all the elements here in the north east. With that said, the previous owner used MDF wood boards for the ceiling, and well over time they warped and bowed. It probably looked great when first installed but I have since removed it and threw it out. What product exists that I can use to cover up the beams and the poor craftsmanship of how it was built ? Once covered up I am sure it will look a lot better, but I at least want to buy a product that can withstand temperatures, moisture, etc. Appreciate the ideas.
Thanks!
rkovelman is offline   Reply With Quote
Old 02-09-2017, 12:23 PM   #2
Rewards Points: 1,514
Re: Sunroom Exposed to Ellements
Any issues with roof or other leaks?
not sure what your room looks like but have you considered T&G cedar perhaps?
ryansdiydad is offline   Reply With Quote
Old 02-09-2017, 12:51 PM   #3
Rewards Points: 78
Thanks for the suggestion, never thought of T&G cedar? Ill have to check it out.
No roof leaks, it is a flat roof that is sloped to allow rain water to run off.
Old 02-09-2017, 01:06 PM   #4
Rewards Points: 4,104
I would also look into replacing the screens with actual windows.
stick\shift is offline   Reply With Quote
Old 02-09-2017, 01:12 PM   #5
Rewards Points: 78
I did and it would be very expensive given that the walls are like 1-2" thick and the size of the screens would require custom glass windows being made. It was a thought but at that point I would want to knock it down and rebuild it and that would get expensive.
Old 02-09-2017, 05:22 PM   #6
Rewards Points: 17,890
http://pgtezebreeze.com/
Yes it cost more but then you would have a real 4 season room and far less damage on the inside.
Hope that was a typo, walls that are 1-2" thick!
Need those pictures.
Old 02-09-2017, 05:43 PM   #7
Rewards Points: 78
Here is an image I have from the summer. You can see its not something that was built out to be much of anything.
multi problem attic and sunroom ice issue indplsin72 Roofing/Siding 18 01-18-2017 07:01 AM
Safe to seal exposed cinder block wall in basement? cne24 Concrete, Stone & Masonry 4 09-20-2012 07:43 PM
Sunroom flooring questions ohman Flooring 5 09-12-2012 02:17 PM
Exposed sheet metal questions ohman Roofing/Siding 6 12-31-2010 10:46 AM
Exposed OSB Primer aero Painting 1 09-12-2010 01:30 PM
