Sump Access Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-22-2014, 07:32 PM   #1
Rewards Points: 31
I have a finished basement and the sump pump room has a door access to the home media room. I'm in the process of soundproofing the media room and would love to eliminate the sump door in the media room altogether.
This is an image of the layout of the area (attached).
There is a finished closet on the opposite side of the door.
What I'd like to do is close off the door and leave a removable access panel on the lower back part of the closet wall. Would this be breaking any codes as long as it is easily removable? I would of course put a backup power supply and alarm on the sump so I wouldn't really need to go in there that often.
I live in VA if this helps at all. If this isn't the right forum, please point me to the right place. Thanks!
Read more: http://www.doityourself.com/forum/ba...#ixzz32UhOiHRA
ClemsonJeeper is offline   Reply With Quote
Old 05-22-2014, 08:00 PM   #2
Retired Moderator
Rewards Points: 7,174
I doubt if there will be a code issue---just make that access panel at least 4 feet tall so the pump and pipe can be lifted out--
Those things need servicing--some times in a hurry--do not make the job a nightmare.
Old 05-22-2014, 08:22 PM   #3
Rewards Points: 31
The wall between the closet and the sump room is about 4 feet wide split in half by a stud. I'm thinking about cutting the lower half of the stud out, bracing it horizontally between the other studs, and then putting the access right under there. 4' tall would be find, maybe 2.5 feet wide or so. So I can still have some use of the closet and be able to close off that door into the theater room.
I'd also likely put an emergency shut off switch in the closet, as well as a battery backup + alarm on the sump.
Old 05-22-2014, 08:28 PM   #4
Retired Moderator
That should be fine---remember if a battery back up is used ,you need to maintain the battery--that might be easiest if the battery/control box was in the closet ,rather than inside the sump pump closet--
Quick question - ACCESS between floors Daugela HVAC 2 04-02-2014 02:00 PM
sump pump basin / pit installation question ipokrov Plumbing 3 01-03-2014 10:25 PM
Question about sump pump cscpianoman Building & Construction 1 10-14-2011 04:57 AM
Plumbing access door question Branden Plumbing 10 11-08-2010 02:18 PM
Question regarding floor drain and sump pump combo vetting Plumbing 9 07-29-2010 01:10 PM
