Suggestions For How To Update A Brick And Stucco Hearth/ Fireplace, Please! - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-09-2016, 06:32 PM   #1
Rewards Points: 2
Question
Suggestions for how to update a brick and stucco hearth/ fireplace, please!
We have a 1970's tract home with a brick and stucco hearth/ fireplace. We want to update the look, perhaps cover the stucco section with something smooth, cover or paint the bricks. Does anyone have any suggestions about what you might do with this?
Thanks.
Suggestions for how to update a brick and stucco hearth/ fireplace, please!-img_8684.jpg
cidercat is offline   Reply With Quote
Old 04-10-2016, 05:08 PM   #2
RickMacKay's Avatar
Rewards Points: 114
Re: Suggestions for how to update a brick and stucco hearth/ fireplace, please!
We did this for a client a few years ago. This portion of their house was built in the 1930's. They had a traditional wood fireplace with a tiled hearth. Ashes were always on the floor, plus it was drafty. We ditched that, raised the firebox off the floor with cinder block, and added a gas insert. We framed the new firebox with porcelain tile. Above it is a rosewood panel. The entire face sticks out a couple of inches, owing to the original construction which was not cost-effective to remove entirely. The ceiling in that spot is about 10' high, and the ceiling is vaulted, so it does not overpower the space. Maybe this will give you an idea.
Suggestions for how to update a brick and stucco hearth/ fireplace, please!-fireplace_before.jpg   Suggestions for how to update a brick and stucco hearth/ fireplace, please!-fireplace_after1.jpg
RickMacKay is offline   Reply With Quote
Old 04-10-2016, 06:13 PM   #3
RickMacKay's Avatar
Rewards Points: 114
Here is another update. The original was a wood-burner from the 1980's framed in that synthetic marble we used to do in showers and tubs. We pulled it out, built a "firebox" out of plywood, brought it off the floor, finished the inside with glass tile, and installed an electric log set. The finished product was wrapped with drywall. Can't get more "modern" than this!
Suggestions for how to update a brick and stucco hearth/ fireplace, please!-thumbnail_2015-04-16-11.08.15.jpg   Suggestions for how to update a brick and stucco hearth/ fireplace, please!-dscn0147-1-.jpg   Suggestions for how to update a brick and stucco hearth/ fireplace, please!-dscn0149.jpg
How do I remove the brick fireplace hearth without damaging the face? alvins Concrete, Stone & Masonry 3 10-26-2014 11:17 PM
stucco fireplace jtaylor1111 Concrete, Stone & Masonry 4 02-12-2014 11:19 AM
Advice needed on stucco above not over brick. tjfitzgerald Roofing/Siding 0 01-12-2014 08:23 PM
4x4 Post Support and Stucco Over Brick Transition ryanb4614 Concrete, Stone & Masonry 1 05-29-2013 02:28 PM
Who has done stucco treatment to fireplace? nativeiowan Interior Decorating 3 07-05-2011 07:56 AM
