Sufficient Weight Distribution Tub Flooring - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-17-2017, 01:43 PM   #1
Rewards Points: 4
Sufficient weight distribution tub flooring
Hello, I am in progress of giving my 1969 bathroom a face lift. The original space had a 12 inch high (60x30) cast iron tub (approx. 450 pounds) which has been broken down and will be replaced with an acrylic 60x32x20.5 (depth) tub with a maximum capacity of 69 gallons. Weight of tub (dry) is 124 pounds.
my concern is in the picture attached circled in red is an area of subflooring that has been cut into pretty significantly to make room for the drain assembly for original tub. The area circled in red flexes pretty easily with just putting slight pressure with my foot. Should I be concerned when the new tub is installed that I may compromise the strength in the area. I don't think my tub (along with me) will fall through to the kitchen below but do I re-enforce that area with some wood from underneath?
Should I be concerned with the original subfloor with this new tub as it will hold significantly more water than original tub but the cast iron tub was about 4 times as heavy to begin with?
Johnsal914 is offline   Reply With Quote
Old 01-17-2017, 03:06 PM   #2
Rewards Points: 17,890
Re: Sufficient weight distribution tub flooring
If it was mine I'd be adding screws to the old floor boards and adding another layer of 1/2 A/C plywood making sure to miss the joist and fastening every 4" on the edges, 6 to 8" in the field.
8D ring shanked nails or narrow 1-1/4 crown staples will work.
Old 01-17-2017, 03:07 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,260
Wouldn't be a terrible idea to pull up that board and brace up the underside via some blocking and thickness.
Old 01-17-2017, 04:00 PM   #4
Rewards Points: 4
Thanks all. Appreciate the advice. Adding additional support is the way i will go with.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
Cork Flooring ametty Flooring 9 11-01-2012 09:59 AM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
