Stupid Backer Board - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-29-2014, 08:13 PM   #16
Rewards Points: 506
Yeah, a do-over seems certain. The Schluter system looks nice. I'm also looking into an acrylic base and wall panel system. Seems to be able to install directly on the floor and directly over wallboard. A local vendor offers the Onyx Collection. No grout lines to maintain sounds nice. Anybody have experience with this?
http://www.onyxcollection.com/
jlmran is offline   Reply With Quote
Old 01-02-2015, 06:29 PM   #17
Rewards Points: 506
I decided to go with Schluter Kerdi. Here is some demolition progress. There was some membrane around the door frame but nowhere else. Not much water damage yet...just a few rusty nails. Attachment 102505 Stupid backer board-image-1334539947.jpg Stupid backer board-image-2580323650.jpg Stupid backer board-image-523560416.jpg
Old 01-03-2015, 08:33 PM   #18
Rewards Points: 4,166
Where's the ventilation.?
ron45 is online now   Reply With Quote
Old 01-03-2015, 08:41 PM   #19
Rewards Points: 18
I can only chime in on Schluter and kerdi waterproofing. I LOVE it, I have done two bathroom remodels and loved it. It's not the cheapest way to go, but sure does work. Only complaint I have is in the corners where they want " overlap" . It causes a slight bulge that is sometimes a pain to deal with in certain tile designs and styles. But I will be using it again on this next project.
jechadell is offline   Reply With Quote
The Following User Says Thank You to jechadell For This Useful Post:
jlmran (01-03-2015)
Old 01-03-2015, 10:45 PM   #20
Rewards Points: 506
See the photo with the light? That is a LVH unit.
Old 01-04-2015, 06:10 AM   #21
Retired Moderator
Rewards Points: 7,174
I've built two bathrooms using onyx wall panels----the customers were very pleased with the results---for that work,I let my granite company do the install----rather a slick, modern look---suited the house well--not my personal taste---but a good look for their modern house.
Old 01-06-2015, 11:38 PM   #22
Rewards Points: 506
So I've hired a tile setter (with Kerdi) and will save a little money by installing the concrete board myself. During demolition I found that the original concrete board was laid over drywall. Is this necessary? Can the concrete board go directly on the studs?
Old 01-07-2015, 06:22 AM   #23
Retired Moderator
Yikes---drywall behind the backer is not good---horrible,actually----Yes---backer board directly to the studs---
Check the studs for alignment---the wall needs to be flat---sister in new studs where needed--
Also--add blocking for safety grab rails---and be sure there are studs where the shower door will be attached---
ben's plumbing (01-07-2015)
Old 01-07-2015, 07:07 AM   #24
Rewards Points: 506
Ok...so is the 'yikes' to drywall behind concrete board simply a statement about water? Or something else?
Old 01-07-2015, 07:12 AM   #25
Retired Moderator
Drywall sucks up moisture--that's why the 'yikes'---with the Schluter system,this would not be an issue---but still,a bad idea and of no benefit to your wall system----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
jlmran (01-07-2015), tylernt (01-08-2015)
Some uneven spots on backer board scotte1975 Tiling, ceramics, marble 5 02-24-2012 01:55 PM
re-using concrete backer board caldew Kitchen & Bath Remodeling 2 02-24-2012 06:36 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 09:18 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 01:30 PM
