Stupid Backer Board - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-28-2014, 01:47 PM   #1
Rewards Points: 506
Stupid backer board
Had 2 cracked tiles near the floor of my shower. Probably letting water escape. My attempt to carefully remove the tiles resulted in crumbled concrete backer board. I think the backer was failed already, contributing to the cracked tiles. Does a fix exist? Or tear it out and start fresh?
jlmran is offline   Reply With Quote
Old 12-28-2014, 01:48 PM   #2
Rewards Points: 506
Oops...should have posted in the bath remodeling section. My apologies.
Old 12-28-2014, 03:58 PM   #3
Rewards Points: 17,890
How thick is that backer?
It should have been 1/2 thick.
Old 12-28-2014, 04:13 PM   #4
Rewards Points: 582
Attachment 100809
well even if you could repair it...it would be only that a repair....you answered your own question even though you were hoping for something eaiser I do that all the time lol...tearing it out and starting over would let you see the whole amount of damage behind the wall ...then you can fix right for good
Old 12-28-2014, 04:15 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I doubt the backer board failed. What I see is an improper installation from the git-go.
Moisture barrier does not lap the pan liner allowing moisture to get to the studs and wall cavity. This is why the mold is there.
Wrong fasteners were used to secure the wall board, note the rust.
My guess is water got through the grout as it usually does, found its way to the studs, the studs got wet and expanded, the expanding studs caused the tile to crack.
You can expect more similar issues as time goes on.
Bad installation, installer error is the problem here.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
ben's plumbing (12-28-2014)
Old 12-28-2014, 04:42 PM   #6
Rewards Points: 506
Originally Posted by joecaption
How thick is that backer? It should have been 1/2 thick.
Yes - half inch, and laid over half-inch Drywall.
Old 12-28-2014, 04:44 PM   #7
Rewards Points: 506
What is the moisture barrier in this scenario? The backer board?
Old 12-28-2014, 05:00 PM   #8
Rewards Points: 454
I don't think it would matter if the backer board was 1/4" its not like you're walking on it
scottktmrider is offline   Reply With Quote
Old 12-28-2014, 05:29 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Backer board is not a moisture barrier. I see something that appears to be behind the backer board, I just assumed that was a moisture barrier and it is short of lapping the pan liner as it should. If it is not a moisture barrier then apparently there is no moisture barrier and that would also be a mistake.
XXX
Old 12-28-2014, 05:31 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It does in fact matter, drastically. One quarter inch cement backer board is never to be used on walls to support wall tile. One quarter inch backer board is intended for use on floors only.
XXX
Old 12-28-2014, 05:34 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Should never be done like that without a moisture barrier. Tile walls are never waterproof, cement board is never waterproof. Drywall expands when it gets wet.
It's in all the books.
XXX
Old 12-28-2014, 05:54 PM   #12
Rewards Points: 506
I see something that appears to be behind the backer board...
Well...that is the paper of the drywall. Darn.
Old 12-28-2014, 10:54 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can expect more similar issues from now on.
Did you do the original installation?
XXX
Old 12-29-2014, 11:40 AM   #14
Rewards Points: 506
No I didn't install. Bought the house in 2012. House built in 1984, but I think this shower install happened later, based on the lumber behind the wall. I've been reading about the Schluter system. Folks (installers) seem to either really love it, or hate it. The hate seems to root from Schluter's customer service. Opinions?
Old 12-29-2014, 03:24 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I am one that loves the Schluter Systems approach, makes more sense than anything else. Makes shower construction and utility an all-together different animal. No reason to hate the system, it just makes too much sense and eliminates all of the issues you are experiencing as well as several others.
The only installers I have heard complain are the one's that think the package is too costly and won't spend the money to improve the quality of their finished product 500%. In my opinion the Schluter Systems concept don't cost - they pay.
Schluter isn't the only company doing such things and offering similar systems but they appear to have pioneered the ideas.
Look into it. You are headed for a total re-do sometime soon so check out the newer methods before you agree to anything with any contractor.
XXX
Some uneven spots on backer board scotte1975 Tiling, ceramics, marble 5 02-24-2012 01:55 PM
re-using concrete backer board caldew Kitchen & Bath Remodeling 2 02-24-2012 06:36 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 09:18 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 01:30 PM
