Structural Engineer/Drafting - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-28-2015, 05:30 PM   #1
Rewards Points: 1,410
A relative is remodeling. On instruction from the recommended structural engineer, he is stalled trying to hire someone to draw the existing setup so a structural engineer can do a design from it.
He's having trouble in not getting a response from people recommended to sketch existing setup.
How would you proceed?
The wall is open, all he wants to do (at this step) is take most of it out and frame around it.
He is taking out a five foot doorway, opening it up to ten feet or so. 1930s house, IIRC. This is under the end of the roof of a main part of the house.
Tom738 is offline   Reply With Quote
Old 11-28-2015, 07:19 PM   #2
Rewards Points: 62
Got a local college? See if they have a CAD dept. If so, students can/will volunteer for small work like this. Makes for more points towards their degree. I use them all the time, but then, I also occasionally teach there.
Trapper6 is offline   Reply With Quote
The Following User Says Thank You to Trapper6 For This Useful Post:
Tom738 (11-28-2015)
Is this wall structural - plans included Zif0684 Remodeling 10 03-25-2014 09:43 PM
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 08:11 PM
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 04:30 PM
Opening up a load-bearing wall. Do I need a structural engineer? Ironlight Building & Construction 3 04-18-2011 11:03 AM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 09:24 AM
